RR issue at startup
  • RR issue at startup
    Hi there!
    I've got an issue with RR. Until today, it started quite well, without any problems. I don't use a flash skin.
    But now, RR hangs at the "Starting Winamp" screen and nothing more happens.
    Anybody has an idea?
    Regards,
    Tobias
    Can you start winamp alone without RR?
    i've had this in the past and just deleted my RR folder and redownloaded.
    肚子笑痛了
    S60 Install
      This is happen when winamp screw up and isn't shutdown when RR tell it to. So when Road runner run, winamp already run, but roadrunner can control it that is why it hang right there trying to "get" winamp. I had this before too. Update to winamp5 for a while then switch back to 2.95
      Y2K Accord Dell GX150
      EmoRebellion is a SCAMMER
        Erm... Winamp isn't running at that time I start RR. If I try to start Winamp standalone, there is no problem...
        perhaps I'll try what jdcillin said...
        Regards,
        Tobias
          Do you have "any" flash objects on the main menu??
          If, so remove them and test it.
            what does your debug.txt file say?
            beer replenishment fund
            mp3car live search
              There are times RR tried to close Winamp on shutdown, and it does not exit properly. As Road Runner runs Winamp hidden, you will not even know it is running. Try the old 3finger salute, and check the task manager to see if Winamp is indeed still running unseen.
              My Fiero Build Thread
                Hum... RR doesn't even create a debug.txt-file, although logging is not disabled in rrconfig. The taskmanager tells me that winamp is running but rr is taking nearly 100% of cpu-power... I tried to delete all of RR and reinstalling it, but the problem remains
                As I told you in my first post, I don't use ANY flash-graphics in my skin.
                Regards,
                Tobias
                  Which skin are you using? Is this doing it on the "standard" BMV skin?
                  When you re-installed, did you use the new installer program here in the sticky of this forum?
                  I'm not answering questions with questions but check the winamp setup for (depending) on the version for "checking automatic updates" turn this off, also check the visual plugins and default it to milkdrop. Also there is a "process" setting for foreground,etc. I will have to look that one up.
                  So if you set the RR config to not embed WinAmp does this happen?
                  Can you show us the RR.ini and the ExecTBL.ini?
