GPS problem with RR running as shell
  • GPS problem with RR running as shell
    With the help of this guide I was able to boot directly into Road Runner. Everything seemed to be working fine till I opened GPS and found out that for some reason GPS is not locking to any settelites. So I imported the orignal registry (with Explorer as shell) file and restarted the computer and everything started working again.
    What could be the connection between GPS unit and explorer ? that it does not work when window boots directly to frontend ?
    Any idea ?
    Update: It seems like Xport is the cause of the problem. When RR loads as shell, Xport does not run. But then when I manually run it, GPS starts working.
    How do I make it load automatically with RR ? Also, when using RR as shell, how can I get rid of RR splash screen ?
    04 Accord Coupe Carputer
    When running RR as shell you need to start Xport3 from the start command in RRConfig.exe.
    RUN;C:\Program Files\Road Runner\Xport\Xport3.exe or where ever your Xport3.exe file is located.
    To get rid of the splash you have to start RR with the /p switch.
      Thanks, I'll try that out
        Try /q instead...as in quiet startup, don't know what /p gives ya...problems maybe...lol
        Next in line: RRMedia v2.0
        DFX 5.1.1 Skin
        Appstore Link
        My RideRunner Plugins
        RRMedia
        RRExtended
        DFXVoice
          You're right. Guess I was writing in mirror image.
            Where do I enter this ? In RRConfig ? Also is it ";" or ":" ?
              Just wanted to say thanks for asking this question... I had the same results and knew it was xport, but didn't find the time to research it yet (and knew I was still tinkering a lot within the OS.) anyway.. now I have my answer.
              Cali
              02 Corvette Z06
              CarPC: 8" Zenarc molded in dash, P3 1Ghz CPU in custom Amp/PC box. RoadRunner, IG3, XM, ODBC (HP Tuners), Cameras
              Pics/Videos
                Right here,
                And ';' go between commands and the paramaters.
                DFX 5.1.1 Skin
                Appstore Link
                RRMedia
                RRExtended
                DFXVoice
                  Thanks a lot for your help. Got it working
