ERROR loading image file(s) for: menu.skin
  • ERROR loading image file(s) for: menu.skin
    *** All fixed, I'd managed to delete the Flash Player!!!
    I had RR running fine on a development machine and then built a "production" machine.
    In that process I removed a bunch of things via the control panel remove programs function.
    Now when I try to start RR, I get the subject error in debug.txt and RR hangs and the task bar is gone.
    I've installed the VB runtime package as well as all the normal RR packages.
    Anyone have any idea what is causing this, where to look, or what I have deleted that I shouldn't have?
    Regards,
    Jim
    Your edit was issued while I was typing !
    Well done for sorting it out.
    kpjuk
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
