OSKtoXXX Problems
  • OSKtoXXX Problems
    I am attempting to use the osktoxxx (ini or var) to set the weather city then reload the weather data using the following command
    "OSKTOvar;cityweather1||setvar;cityweather;$citywe ather1$||reloadweather"
    The command properly brings up the keyboard and set the cityweather1 variable but does not transfer it the the cityweather and reload the weather until another push of the button. It appears to be executing the remainder of the command without waiting for the input, but will properly assign the varable upon re-execution. I have read the OSK delay thread and loaded the beta but it still does not work. Any suggestions?
    try
    Code:
    "OSKTOCMD;cityweather1;REOPENWEATHERNEW"
    put this in ExecTBL.ini
    "REOPENWEATHERNEW","setvar;cityweather;$cityweather1$||reloadweather"
    2001 S10 ZR2
    Chucks Skin - to old
      Thanks Chuck!!! That works, not how I wanted to do it, but it works.
      But is there indeed a problem with the other commands executing before the osk input? Just for future reference.
        OSK Issue
        Yes, this is indeed a problem, and I went at one point when setting my skin up trying to figure that out. Creating a command in the exectbl was the only workaround I could find, thanks also to Chuck's help
        My Fiero Build Thread
