Powerdvd control from roadrunner
  • Powerdvd control from roadrunner
    Hi, I'm using Powerdvd 4.0, and I am pretty sure this is a skin issue, but I'm not sure what to do to correct it. The problem is that the non-flash powerdvd skins do not control powerdvd at all, but the flash version does so pretty well. (flash skin I'm talking of is freedom 2.1).
    What I've done so far:
    *tried 3 different non-flash skins which none of the work. . .blue devil, bmv2, and crystalblue skins.
    *In these 3 skins, changed menu.skin dvd button to:
    B05,2,331,359,128,"load;powerdvd_player.skin"
    *Tried the skin as is, then changed the buttons to reflect the hotkeys in my powerdvd helpfile:
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B13,18,0,67,86,"MUTE","Mute"
    B02,85,0,66,86,"VOL-","Volume-"
    B01,151,0,64,86,"VOL+","Volume+"
    B03,235,0,67,80,"Sendkey;LR","Root Menu"
    B11,235,80,67,75,"Sendkey;LT","Title Menu"
    B09,325,75,62,78,"Sendkey;P","Up"
    B05,387,75,66,78,"Sendkey;{PGUP}","Prev"
    B07,453,75,62,78,"Sendkey;S||EJECT","Stop/Eject"
    B06,516,75,66,78,"Sendkey;ENTER","Play"
    B08,582,75,66,78,"Sendkey;{PGDN}","Right"
    B10,648,75,61,78,"Sendkey;N","Down"
    B12,730,77,68,86,"EXIT","Exit"
    Here's the original version from each of the skins:
    B03,235,0,67,80,"Sendkey;{ENTER}LR","Root Menu"
    B06,516,75,66,78,"Sendkey; ","Play"
    What am I doing wrong? Why does it work in freedom 2.1 and not in roadrunner?
    Celeron 2.53 Ghz Processor
    512M ddr memory
    Mimo 7" USB Display
    XM Direct Tuner
    mp3car.com XM Direct USB interface box
    1999 Mustang GT Convertible Supercharged
    You can find out exactly the codes used in the flash skin by making a debug log, then just placing those commands in the non-flash skin.
    Ride Runner RR's Myspace
      sounds good. Didn't think of that. Thanks!
      512M ddr memory
      Mimo 7" USB Display
      XM Direct Tuner
        Thanks for the help! I'll try the Idrive skin for powerdvd. Right now, I just copied the flash skin from freedom into the other directory.
        512M ddr memory
        Mimo 7" USB Display
        XM Direct Tuner
          works great. Good job!
          512M ddr memory
          Mimo 7" USB Display
          XM Direct Tuner
            I haven't played with that yet, but I'm going to try it. Thanks again!
            EDIT:
            Yep, You were right. That change fixed it for even my BMV2 skin for powerdvd. Thanks!
            512M ddr memory
            Mimo 7" USB Display
            XM Direct Tuner
