skinning winamp media library
  • skinning winamp media library
    I cannot seem to catch the window or class name of winamp media library. Tried both names from winspector-spy. I can make Winamp Library catch in launch, but not as a button. can anyone help? I also would like to make the fonts much bigger in media library, anyone know how to attempt this?
    thanks
    s1
    This is what I did to run 2.xx or 5.xx
    Code:
    "WINAMPLIBRARY","SHOWWINDOW;library;False||LOAD;LIBRARY.skin;library;;library||OPENLIBRARY||RUN;;library"
    "OPENLIBRARY","BYVAR;OPENLIB;OPENLIBRARY2<<"
    "OPENLIBRARY2","ACTIVATE;Playlist Editor||SENDKEY;%f||SENDKEY;l||SENDKEY;mm{ENTER}||SETVAR;OPENLIB;1"
    2001 S10 ZR2
    Chucks Skin - to old
      Chuck-
      Thanks for the quick reply. Ive used your code, and it does work much better than mine. However, it still isnt skinning. It does however, call the window and i have placed it into the proper position. I would like to skin it about 50px down from the top and 70px from the bottom. Any ideas on how to catch the class? spectorspy doesnt seem to give the proper name/class i imagine.
      Thanks again,
      s1
        Post your library. Skin file so I can see it
        2001 S10 ZR2
          thanks
          s1
          Options>Preferences>Playlist>Playlist font size _
          Options>Preferences>Media Library>Library Options tab>Modify Settings(lower right button)>Media Library uses same font as Playlist Editor
          beer replenishment fund
          mp3car live search
            Chuck-
            LS helped me a while ago on how to structure the exectbl file for LSX VOID, which i believe was originally developed for your skin. I Really appreciate both of you being on this thread, as this is my first attempt to hack the exectbl file (inside the LSX Void - Current Release, with RR Current(manual install)), and Winamp 5 Current (full) as it streams asx/mms properly without the /.wma hacks.
            Attached are the medialibrary.skin file and exectbl.ini. Im sure as you look through the file, you will laugh, then call me names, then laugh some more! I couldnt match up the FREE49/50 tags, so i decided to use both of them. I had also tried it with a fresh exectbl file, as i saw the DONT MISORDER THE TAGS messages in the LSXVOID/EXECTBL file, but it seems that it occurs on both files.
            Thanks in advance guys, i have been trying to figure out a way to implement online media for quite a while. I have been through ymp, live365 (pro), audiostreamer, screamer, as well as a few other apps that just dont work well for online streaming/driving.
            I eventually would like to have 2 copies of winamp running. One for the audio library, which is the current integration into rr. And another for the media library; this way when a track is run from the ML, say its a podcast/stream/etc, it will not mix with the current playlist from winamp which sits inside rr.
            thanks again guys, you two +guino seem to make the RR SCENE ROCK!
            sideone
              damnit, cant believe i missed it; thought it would require WA skin hacking.
              looks like you need some more beer!!!
              s1
                Just what I thought you forgot the application area
                /, A, x, y, w, h, color;RGB
                A,16,57,990,470,
                2001 S10 ZR2
                  Also here is a faster way to start your SETUPMENULABEL
                  Code:
                  /,24---------------------Step 3 change Menu Label------------------Main Bottom Button Menu Labels---------------------------------------------------------------------
                  /,                                  ------01-----------02---------03---------04--------05-------------06--------------07-------------08-------------09-----------10----------11-----------12----------13---------14---------15----------16----------17---------18--------19--------20--------21-----------22------------23------------24--------------25---------26----------27-------------28----------29-------------30----------31---------32--------------33----------34---------35-----------36------------37-----------38-----------39-----------40-------------41------------52------------43---------44----------45---------46------------47----------48----------49----------50---
                  "SETUPMENULABEL01","SETVAR;MENULABEL;=Audio MP3's<<=FM Radio<<=XM Radio<<=ATI  TV<<=Video Player<<=Nav-iGuidance<<=Calc & Cal<<=Play / Pause<<=Tools Main<<=Web Browser<<=Note Pad<<=Street Atlas<<=CD  Rip<<=Weather<<=Radar Maps<<=WiFi Scan<<=Scanner<<=Auto Tap<<=Gas Log<<=Outlook<<=Launcher<<=Touch Games<<=Nav Copilot<<=Traffic Jams<<=Connect Menu<<=RR  TV<<=Audio Presets<<=Auto GPS<<=Alarm Clock<<=Reload Skin<<=Quit RR<<=$MP3LABELS01$<<=Tools Apps<<=Pick Color<<=Library<<=Sirius Radio<<=Trip Meter<<=Gas Prices<<=Song Remind<<=DVD Player<<=Power on/off<<=GPS Volume<<=Maintenance<<=Gauges<<=Check List<<=Test Skin<<=Sirius Mute<<=XM  Mute<<=Pic Viewer<<=Changer||SETUPMENULABEL02"
                  "SETUPMENULABEL02","SETVARFROM;MENULABEL;AP01LB<<AP02LB<<AP03LB<<AP04LB<<AP05LB<<AP06LB<<AP07LB<<AP08LB<<AP09LB<<AP10LB<<AP11LB<<AP12LB<<AP13LB<<AP14LB<<AP15LB<<AP16LB<<AP17LB<<AP18LB<<AP19LB<<AP20LB<<AP21LB<<AP22LB<<AP23LB<<AP24LB<<AP25LB<<AP26LB<<AP27LB<<AP28LB<<AP29LB<<AP30LB<<AP31LB<<AP32LB<<AP33LB<<AP34LB<<AP35LB<<AP36LB<<AP37LB<<AP38LB<<AP39LB<<AP40LB<<AP41LB<<AP42LB<<AP43LB<<AP44LB<<AP45LB<<AP46LB<<AP47LB<<AP48LB<<AP49LB<<AP50LB"
                  2001 S10 ZR2
                    A,16,57,990,470,
                    Chuck,
                    sorry i am still a little new on this. Could you explain what this area is, and how it relates/knows this area will be for the app?? i believe i have seen this type of reference inside rrskineditor. If this is a basic question, could you please point me to a faq on this subject?
                    thanks again,
                    s1
                      tried adding the app area, but still isnt catching. im attaching the current.
                      thanks,
                      s1
                        like this
                        this is where the app will show - A,16,57,990,470,
                        Code:
                        /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
                        L,8,6,533,25,128,128,128,16,"Arial:B","TAGARTIST||=   -  ||TAGTITLE","SCROLL-RIGHT"
                        L,0,0,0,0,0,0,0,12,"Arial","GPSSPD",
                        L,625,8,160,27,192,192,192,18,"Arial:B","DATE","RIGHT"
                        L,22,437,61,21,192,192,192,18,"Arial:B","=_","LEFT"
                        L,352,444,34,28,119,0,0,18,"Arial:B","=+","RIGHT"
                        A,16,57,990,470,
                        2001 S10 ZR2
                          i have tried that, but no luck, seems like the window wont embed. does my attachment look correct with the application area?
                          s1
                            s1
                            try this
                            2001 S10 ZR2
                              thanks for the help chuck.. looks like were getting closer! now it seems that its skinning other applications as well as the media library. for example i was using notepad to work on the skin file, and lost the notepad app; it still shows in the process manager, but its somewhere inside rr, and i cant find it!!
                              i also am unable to close winamp/rr when i exit rr. RR runs at 100% for a few mins when trying to close. Ill debug in a bit.
                              I also tried updating the font size, and could not find the modify button in the current 5.x build of winamp. I did find the playlist editor font size, but it only modifies the left column. I would like to modify the right side, where it shows the station name.
                              thanks,
                              s1
