Terratec Home Cinema won't Embemmed
  • Terratec Home Cinema won't Embemmed
    Hi!
    I've a big problem with my Cinergy Diversity TV (DVB-T). I must use the Terratec software for the diversity function. Software is Terratec Home Cinema. This sw have 2 windows, one with the live tv and one with the channel buttons, volume ecc ecc...
    I've to embemmed the fist window but if i close the program and reopen, his class and window name isn't equal....
    any idea??
    http://www.quickmic.at.tt/Public/TV_1.4.ace
      I am anxiuos to buy one of the terratec diversity but has hesitated because I am not sure if it works in winampTV plugin.
      Have you tried it in the winampTV plugin?
      http://www.tv-plugin.com
      AOPEN MINIPC 945 VXR, CORE DUO T2400, 512MB, 120GB, Wlan, CARNETIX CNX-P1900, 1020TSV TFT 10.2" Touchscreen, BU-353 GPS, wlan-antenna, X3 integration to HU, D-link DUB-H7 USB 2.0 Hub, Wireless RF-keyboard, Logitech USB noicecancelling mic, NV RVcam
        GEIL..it works perfect in my home pc.
        what im looking for is a good proggi for my car pc dvb-t -HAUPAUGE WinTV-HVR-1100 DVB-T + Radio-.
          @crispyrabbi
          I tried it with the TV-Plugin, but the diversity-function isn't supported. Only two tuners are available. I also wrote a mail to the programmer of the TV-Plugin if he could include this function. Till now I got no answer.
          Cause of this, I wrote this tool to embed the original software.
            Thanks for the info! I have a few other questions....
            So how does it embed? Can you access it through the TV button in RR or do you have to go through the app function? Does it work with CDrskulls Freedomskin? Does it work when you drive in high speeds?
            I have the terratec T2 DVB-T and it works great when the car is not moving but stops right away when you drive. Of course its not a dual DVB-T.
              The tool embeds the "TerraTec Home Cinema" which uses most (mayby all?) of the Terratec-TV-Hardware.
              So you can try it with your T2.
              The menu is not the original from "TerraTec Home Cinema". It's new created for touchscreen-handle but it's not skinable for now. Best way you see yourself.
              The tool is a standalone exe program. It also works with other frontends, not only RR.
              I read in other forums that the Terratec-diversity-version should work up to 90-110km/h. I didn't tested it by myself, that comes this weekend
                sorry but i have problem to unzip TV 1.4.ace,
                Why?
                  hey man!
                  i won't embedded the software of terratec diversity!cab i realise it?how?
                  thanks
