Strange embedding GPS problem
  • Strange embedding GPS problem
    Ok, I am having a hard time embedding iGuidance into a custom music player skin.
    Acording to the SkinCommands.txt file, to embed a defind application into a skin, the following command is used:
    "AUDIO" - Loads the Audio Player Screen (audio_player.skin) -- Same as "LOAD;AUDIO_PLAYER.SKIN;MUSIC"
    Well, I am attempting to sue the following command on a button to load the GPS into the custom skin:
    Code:
    "LOAD;Audio_GPS.skin;GPS"
    The syntax is correct according to the Skin Commands file, unless this only works for "internal stuff" and not for an external application.
    I also tried the following, copying the below command somwhat by passing on the window title:
    Code:
    "LOAD;Audio_GPS.skin;GPS;iGuidance"
    This also does not work.
    The following command Works perfectly so I know the skin is set up correctly, as far as the application area ect. I just want to avoid Hard Coding the GPS program, so whatever is set up in th rr.ini will work.
    Code:
    "LOAD;Audio_GPS.skin;iGuidance;C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe;iGuidance"
    Am I missing something totally obvious or simple here?
    My Fiero Build Thread
    I take the dead silence as basically meaning that "I am up that well known tributary, without a proper means of propulsion." Otherwise known as USCWAP
      if I understood correctly, you want to use the GPS app defined in RR.ini, right?
      can't you use it's variable? like this:
      Code:
      "LOAD;Audio_GPS.skin;iGuidance;$gpspath$;iGuidance"
        Thanks!
        Duh! Hahahha with only 4 posts in the forums, you have certainly stated the obvious that just went right over my head!
        Thank you! That did the trick. I didn't think about trying it that way. Still kinda odd that the GPS command doesn't work as in my first post.
        Thanks!
          Well, normally I am going hidding during weekend.
          "I think" the reason it doesn't work because of custom skin with a pre-define command.
          Code:
          That doesn't work but the following work
          Code:
          I don't know why the LOAD and GPS doesn't work (I guess double translation because GPS command seem to load external_gps.skin, and gps option/setting in RR).
          If you do search regarding $gpspath$ and $gpsname$ I posted in serveral thread, those are variable in RR that you can use in skin instead of typing the whole string every time like below.
          Code:
          "LOAD;Audio_GPS.skin;$gpsname$;$gpspath$;$gpsname$"
          Y2K Accord Dell GX150
          EmoRebellion is a SCAMMER
            Code:
            Thanks Matrix, thats what tiagos posted a a couple posts back, and I got it working perfectly.
