question about transitions
  • question about transitions
    what would make my transitions (between different screens) faster? better video card? more ram? faster cpu? im using the fade transition (#0) and its so slow that it almost looks bad. and then my computer is slow on top of that so it takes a few seconds after i hit a button before it goes to the next screen.
    i guess this question is turning into how do i make RR faster and how do i make the transitions faster? (which i assume will happen if i make RR faster...) thanks
    It would help to know what your CPU, Ram and GFX card are now to kind of get an idea what it could be.
    Taking a couple seconds to respond to a button press is not normal, even on most of the slower machines. You could possibly have a flash version issue, but its hard to tell with the info you have given so far. Open the task manager, and see what your CPU is doing when RR is running. If it's maxed at 100% then there is something not right somewhere.
    My Fiero Build Thread
      ok, first of all im running liquid_smoke's lsxvoid skin (the old one). i dont think it has any flash in it...? not that i have discovered at least. anyway, its a crappy computer -its just one that i have had lying around and i figured i might as well use it.
      1.00GHz intel celeron
      256mb ram
      running nlited windows
      ati 128mb pci card
      creative audigy sound card
      without RR running the cpu usage is "0%"
      with RR running it holds around 22% (+ or - 5%)
      with the VISU on, it spikes to about 90% and stays there (ouch)
      - i know that that my AVS visu eats my processor alive
      and lastly, my page file is 149mb with nothing running and 169mb with RR
      im beginning to wonder if its that stupid CPU's fault. is there anyway i can change the transition speed or make RR switch between screens faster? RR works great on my other computer running onboard video so i dont think its the video card's fault. thanks
        RR doesn't use hardware acceleration (for compatibility purposes), so CPU is definitely the answer.. though, I must warn you, everything is timed to an average of half-second minimun between screens so even at blazing speeds, it should still be visible.
        Ride Runner RR's Myspace
          ok, yea well sometimes my computer takes like almost 10 seconds to switch screens. thats a little more than half a second. even one or two seconds would be great. the fade transition just looks a little funny when it takes like 4 seconds for the skin to completely fade into the next. but thanks for the info about the cpu. now to find a cpu that doesnt eat much power but is fast.....
            Well this is semi-OT, but since the OP's question has been answere,d I'll go ahead and ask..
            Why the half second minimum? and.. ..is there any way to disable it?
              the RR source is published, so I would take a look around in there. Also, it's written in VB (not .NET), which could contriblute to the lag (at least it's not java )
              2002 Acura RSX CarPC Worklog
              Current CarPC Expenses
                Haha true, I suppose I could get in there and disable it myself. Was hoping for a config file or something of the like though.
                Well now I'm off to see if I can find more info about how to enable this 'transition' effect..
                  You can configure transitions both on a global scale or on a per-screen basis.. just make sure there's no transition= line in RR.INI to disable it all together. There're plenty of posts talking about those options. /EFFECT is the parameter that can be in the .skin files to set the transition when leaving a specific screen.
                    Awesome! I've enabled transitions and it really does enhance the experience. I still do notice the .5 second delay though. Is there any way to decrease or even disable that? I've searched on it but haven't come up with many discussions about it.
                    I'll go poke around in the config files a bit.
                      Well I've looked in all the config files but haven't found anything. I've also taken a quick look in the source, but with my limited programming experience.. ..I'm going to need someone to point me in the right direction :P
                      Either that or beg for the delay to be removed, lol..
                      Any help is greatly appreciated!
                      Thanks,
                      -Chris
                        transitions slow my computer down to a crawl. and its a 2Ghz laptop with over a gig of ram.
                        Hell it boggs my dev laptop down to a crawl. and its a dual core machine.
                        No hardware accelleration and VB6
                        If you want transitions just be carefull. Jumping from one screen to the next or pushing buttons too much tends to kill things.
                        Car : 00' Chrysler 300M
                        Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
                        Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
                        CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
                          I'm using a Epia M10k (512mb ram) with the transitions and the only trans that is slow is the fade, which is the way it should be as that req a lot more power...all the other effects are fine..
                          Next in line: RRMedia v2.0
                          DFX 5.1.1 Skin
                          Appstore Link
                          My RideRunner Plugins
                          RRMedia
                          RRExtended
                          DFXVoice
                            I've been using fade on a 2.2GHz Celeron and it seems to be running fine..
                              it was fade that I was using, so probably thats why
