2 commands at 1 button in skin possible?
  • 2 commands at 1 button in skin possible?
    How do i make 2 commands executed using just 1 "button" on my skin,
    I want the regular function like : B,x,y,h,w,"MUSIC","MUSICPLAYER"
    turned into something like this : B,x,y,h,w,"MUSIC","SpeechCMD "Hello World"
    Hi Teaser,
    You can use the following syntax, the @string@ is the command when you press and hold the button. Don't know if this helps.
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B020,896,007,129,70,"VISU",@LOAD;Exit_Menu.skin@
    In your case it would be something like
    B,x,y,h,w,"MUSIC",@SpeechCMD "Hello World"@
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
      in your example, the only part that's different is the tooltip...
      but, answering your question, it's possible to have 2 commands in one button, just use || between commands. something like:
      B01,x,y,w,h,"COMMAND1||COMMAND2","tooltip"
        B,x,y,h,w,"MUSIC||SAY;Hello World",""
        2001 S10 ZR2
        Chucks Skin - to old
          great,gonna try it!
