Full Support for Phidgets Interface Kit - Finished!
  • Full Support for Phidgets Interface Kit - Finished!
    See attached, search the code for greenman100 if you like. meant to be compiled with 11-12-06 version.
    button commands:
    phigdonXX - turn on digital output XX
    phigdoffXX - turn off digital output XX
    Indicator:
    phigdoXX - returns digital output XX state
    phigdiXX - returns digital input XX state
    here's the roadrunner.exe
    http://www.filefactory.com/file/a8ddc4/
      good work man, now i just need my new car, a phidgets kit, and a carpc, so i can ditch the climate controls
      cashtexts - Earn money for receiving text messaged offers
      cashtexts review not a scam
      Space Navigator - 6 Axis input device: Take it apart - Driver App
      RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
        Ok, I had no idea what a "phidget" was till I did a quick Google This looks like it could open up a pretty big world to the already amazing RR front end.
        Has this been submitted to Guino, so it can become part of the official releases?
        With a little research, I can see this used so many ways! Of particular interest is the Distance sensor Phidget to place on the rear of the vehicle for distance to an object when backing up. (Good for a range of just over 2 feet)
        Now for a question
        Can the input be turned into useful data with Road Runner? For instance the distance sensor, mentioned above, outputs a range of numbers from 0 to 500. Having that converted to the actual distance would be much more useful.
        My Fiero Build Thread
          Now for a question
          many of the sensors already support conversion through a tooltip:
          Code:
                  Case "c2f"
                      'Show in C
                      N = N - 200: N = N / 4
                      N = (N * 9) / 5: N = N + 32
                      GetPhid = Format(N, "0.0F")
                  Case "f2c"
                      'Show in F
                      GetPhid = Format(N, "0.0C")
                  Case "volt"
                      'Show in V
                      N = N - 500: N = N * 0.06
                      GetPhid = Format(N, "0.00")
                  Case "50amp"
                      'Show in Amps
                      N = N - 500: N = N * 0.1
                  Case "15amp"
                      'Show in Amps
                      N = N - 500: N = N * 0.03
                  Case "gp"
                      'Show in Pressure
                      N = (N / 4) + 10
          I could add code for the rest later, but I really need people to beta test the code to confirm it works before I submit anything to guino.
            your code is for digital i/o not sensor reading, right? theres already commands in skin commands.txt for reading phidget sensor data. is it possible to do math and/or simple scripting in the skin files, or would that have to be output to a specific program for proccessing?
            sorry for goin off topic, but yea, your code, digital i/o not sensors..
              Is the EXE still available? I can't get the above link to work, but I'd like to test out the Phidget integration.
                scrol abotu halfway down and click on 'Download for free with FileFactory Basic'
                  yes, this is jsut for digital i/o, analog is already built in.
                  the code above allows for predetermined conversions in the skin files. I could probably expand the functionality to do any sort of math.
                    Ah very cool i'll have to spend more time with skinning in RR.. using your addition, i can have a nifty lil setup that keeps my car at whatever temp i want
                      yup, already done this
                        here's my skin
                          WoW, I guess I should have done a little more research into this. I was not even aware that RR already was able to support an analog version of this.
                          I knew that RR was capable of simple conversion from Fahrenheit to Celcius, but was not aware that it extended to plugins (such as this one) as well.
                          I just need to take a step back and familiarize myself a little bit more, before asking such simple and redundant questions. I was acting so much like a newbee here! (NOT that that is a bad thing, as that is how we all learn).
                          Thanks for all the info!
                          This code is gonna add a lot of functionality to RR on top of what it is already capability of!
                            Any plans on adding functionality for the motor control kit?
                            2004 Ford Mustang Mach 1
                            Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
                            Install Status: DONE
                            My XM FAQ
                              if people chip in to buy me one, I'd be happy to.
                              I can't test it or write code without one, though.
                              http://www.phidgets.com/index.php?mo...138.55&IID=112
                              $70.
