Calibration performed for NTC probe w/ Phidgets
  • Calibration performed for NTC probe w/ Phidgets
    So, I calibrated a NTC probe:
    -- AVX Type NI24 --
    with a 463 ohm resistor, in a voltage divider arrangement.
    From 35 Degrees F to 190 Degrees F.
    I can say with 95% confidence that the following curve fit equation is accurate to +/- 1 degree from 35 degrees to 190. In some cases it is better than .3 degrees F accurate.
    N = -1.4618 * N ^ 6 + 21.062 * N ^ 5 - 127.38 * N ^ 4 + 409.96 * N ^ 3 - 731.9 * N ^ 2 + 626.52 * N + 10.658
    Where N is the phidgets sensor raw value.
    I've incorporated this logic into the latest revision of the RR source code.
    PM me if you need some of the thermisters, they're more accurate and cheaper than the phidgets variety.
    http://i2.ebayimg.com/04/i/06/ff/90/56_1.JPG
    Compare to Phidgets, which has an accuracy of +/- 4 degrees F, and are mounted on a board....these thermisters can be epoxied to anything.
    Great work, good find.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
      Originally posted by greenman100 View Post
      From 35 Degrees F to 190 Degrees F..
      35???
        Originally posted by GizmoQ View Post
        35???
        yes, I calibrated them in a variable temperature water bath. Below 35 and I risked freezing, and I didn't seen a need to go above 190. They'll work below 35, just not be as accurate.
          care to share the code ? If I can merge it the main sources, you won't have to add it when new releases come in. Just email it to me (my email is on my public profile).
          Ride Runner RR's Myspace
            by now, between this and the other thread, there is sooo much. I think I commented it all, but I'm not sure. I had to modify frmLoader, frmSkin, and modRoadRunner. Is that ok?
