iGuidance Integration Problems
  • iGuidance Integration Problems
    I am using iGuidance v 3.0, and it works fine in windows. I am also using the latest version of RoadRunner with a scion tc skin.
    In road runner config, I have setup the GPS section for it to have the GPS window in road runner.. but it doesn't work for me.
    In RRConfig, I have the following settings:
    GPS Mode: External
    GPS Path: C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe" "nowarning
    GPS Window Name: !IntellisnavWCls!IGuidance
    I have also tried removing and switching the window names, i have tried setting the parameters for the GPS path differently, ie:
    GPS Path: "C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe" nowarning
    ...and everything else I can think of..
    The ONLY way I can get it to work, is if I already have iGuidance running when I startup Road Runner. When I click GPS, it works and comes up fine.. then if I go to close Road Runner, and exit back to windows, I see that the iGuidance window is gone, but the iGuidanceUMPC.exe process is still in the task manager.
    Yes, I've tried searching for similar problems, but can't find much - and by the way this forums search methods are awful!
    Brett
    www.QRXX.com
    http://www.mp3car.com/vbulletin/showthread.php?t=95213
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
      Thanks for the link.
      I looked through the threads that were in the threads you linked to, but still cannot get this working. Maybe it is a skin problem? I've tried editing the rr.ini with the suggested settings, but it still doesn't properly work. I'm not sure what else to try.
      Brett
      www.QRXX.com
        Post the GPS portion of rr.ini
        what skin are you using?
        What is the code to run GPS? Remember, some skin, the skinner hard code the GPS button to use LOAD command instead of just "GPS".
          Not sure if this is the problem or not, but in GPS Window title in RRConfig, I simply have "iGuidance". I am also using iG 3.0. With the window "disappearing" it sounds like a window title problem, and RR is not able to get a "lock" on it.
          This is from my RR.ini:
          Code:
          gpsmode=2
          gpspath=C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe
          gpsname=iGuidance
          My Fiero Build Thread
            The skin i'm using is from another mp3car memeber's thread..
            Its called "system error (blue)".
            http://www.mp3car.com/vbulletin/showthread.php?t=69105
            My complete rr.ini file is here:
            http://qrxx.com/carpc/rr.ini
            The GPS Parts are:
            Code:
            gpsmode=2
            mapmonkeypath=
            gpspath=C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe|nowarning
            gpsname=Iguidance
            Note that I have tried the gpspath different ways.
            I don't have any setting for ignative, although i have seen that posted, but i was under the impression it was not needed.
            I've also changed around the gpsname using winspector, to IntellinavWCls.. i think that was it, anyway it still doesn't work unless iguidance is already running.
            Thanks,
            Brett
            www.QRXX.com
              Code:
              gpsmode=2
              gpsname=iGuidance
              Still doesn't work.
              But thanks.
              www.QRXX.com
                Originally posted by zzzBrett View Post
                Still doesn't work.
                But thanks.
                Hmmmm not sure what it is then. I can tell you you can remove the |NOWARNING from the end of the line, as RR now takes care of that since around the end of October. I doubt this is the problem, but it can be removed anyways.
                  Its fixed!
                  I downloaded and setup another skin, used it.. and the gps worked.
                  Then, I went back to the system error skin, and it worked too!
                  Kind of weird, but i'm just glad it works now.
                  Thanks for the help,
                  Brett
                  www.QRXX.com
