question about gestures
  • question about gestures
    after testing out both streetdeck and road runner i ended up picking road runner. but i really dislike how in road runner anything moving on the screen stops while you do your gesture, can i fix this? also can i change it from the red ball to the cool looking blue line that streetdeck has? im making my own skin right now and thought i might be able to do it that way.
    Using gestures with Road Runner
    You can turn on and off gestures completely, or define an area you do not want gestures to work. For instance on your GPS Map area(Gestures prevents you from dragging the map in such a screen.) You can also make a few or as many gestures as you want. For instance I do not use gestures to "type" and have removed all the alphabet codes from the gestures.ini.
    You can change the "Red Ball" to anything you like. Just create a "GESTURES.BMP" image. You can then place this in your skin folder of your choosing. This allows each skin to have a gestures image that more matches the skin in use.
    My Fiero Build Thread
      sweet i got my new gesture working great . i still need to figure out how to make everything not like pause/freeze while i do gesters
