Sirius shows mp3 list-xm logo , not channels
  • Sirius shows mp3 list-xm logo , not channels
    I cant figure this out (screen shots below).
    When I click the sirius button in either skin RR shows the XM banner and my mp3 play list and does not tune sirius channels.
    My sirius connect is on com5 and works with sirius recorder.
    Steps I have taken.
    upgraded RR using auto updater.
    uninstalled RR and installed manually
    uninstalled RR and auto-installed/updated
    deleted and re-installed skins each time
    used both the usb driver that came with sirius connect and the latest from the web
    updated flash player
    updated windows
    HELP!
    Intermission....
    I am having the same issue, did you get it sorted out?
      Originally posted by sentiensx View Post
      Steps I have taken.
      updated windows
      HELP!
      A couple things you did not mention. Did you change the settings in RRConfig? You have to put a 0 for XM port in there, and the port that your Sirius device is on for Sirius.
      Secondly, you need to open the menu.skin in notepad, and find the line with XM in it, and change it to "SIRIUS".
      For the BMV2 skin it would be this line:
      Code:
       B06,11,305,339,106,"XM",""
      and change to this line:
      Code:
       B06,11,305,339,106,"SIRIUS",""
      Hopefully that will get you guys going.
      My Fiero Build Thread
        Yes, XM is set to 0 and Sirius is on com 5 and set that way in config and confirmed in ini. I tried renaming the xm skin to sirius at one point and that just changed the xm logo to the sirius logo.
        OK, That totally worked and now RR totally ROCKS!! Changing the menu.skin fixed it.
        Was that a total newb mistake on my part or what? I didn't see that documented anywhere.
        One thing though, now the play list is correct and it friggen works so I dont really care too much but the sirius logo is gone from the upper left.
        JohnWPB -Thank you so much!!! I had all but given up. Spent a whole weekend working on this.
          Sentiensx,
          I am having the same issue. Sirius works in RR but it is saying that it is not activated and to call the number. Which when I open up satamp it shows all the channels and works perfectly. Do you know what I am dong wrong?
          Cameron
