iguidance closes on skin switch
  • iguidance closes on skin switch
    using the 4-11-07 version when i switch skins, iguidance gets closed. this is only a problem when running the gps around when the sun is setting and rr changes from day to night skin and the destination is cleared. i didn''t think the setting for closing embedded apps on exit would make any difference but i've disabled it and it still does the same thing. does this happen to anyone else?
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
    finally someone else that has this problem.. its the most annoying thing ever to me. It has something to do with iG Native. I will set a route.. change to a skin and randomly the route gets cleared when i switch back to my iG screen. I mentioned this in the iGNative thread awhile ago but noone seemed to have the same issue. Its skin-independent... doesnt matter which version i'm iG i'm using and i cant seem to come up with a reason why it happens... as far as i know u cant even send a command to iG to clear the route.. there's no keycommand for it.
    Live mp3Car Facebook Chat
      You guys are not the only one who has this problem. I am too, but 4-11-07 release is the only version I have problem with.
      I'll take a look at the code to see what happen.
      Y2K Accord Dell GX150
      EmoRebellion is a SCAMMER
        FYI..
        I have also noticed this while working on my OCR app...another command that closes iG is "reloadskin"
        Nice Sig BTW, Maxtrix....
        Next in line: RRMedia v2.0
        DFX 5.1.1 Skin
        Appstore Link
        My RideRunner Plugins
        RRMedia
        RRExtended
        DFXVoice
          The fix I posted also taking care of the reloadskin command as well because reloadskin execution is also within the skin selection block. .
            iG is probably crashing/closing because it's embedded INSIDE RR's screen, and not being unembedded before the screen is unloaded. It shouldn't be hard to compare the application title and if iGnative=true just unembed it first, then everything should work as usual. Maybe MatrixPC already fixed it ? :|
            Ride Runner RR's Myspace
              yes guino there was a beta release done sometime last week that seems to be working fine
                i just tried upgrading to the latest 11-02-07 version of rr and this bug appears to have resurfaced. i've gone back to using the 4-30-07 version that had this fixed for the time being but i thought someone might want to know.
                  i'm also having my iguidance close out randomly when i'm not longer on that screen. i dont know if it has something to do with the screen leaving memory after visiting several screens in between or if it has to do with some bug in ignative (which i am using along with autosw). can someone please further explain how to correct this?
                    There is a new setting in the rr.ini, sorry, I do not know who added it *matrix?), and I just saw it on the forums some time ago, tried it, and it works. I see no mention of it in this thread, so hopefully if someone else stumbles upon this thread, it will help them.
                    Put this line in the rr.ini:
                    EmbedAppList=iGuidance
                    This should keep RR from reloading iGuidance when the skin is switched / reloaded.
                    My Fiero Build Thread
                      this works for switching skins manually but if the "DAYSKIN" or "NIGHTSKIN" command is used, iguidance is closed and reopened when the new skin is loaded.
                        Also, see the General>Page 4 in the config. To add\remove any embedded apps.
                        DFX 5.1.1 Skin
                        Appstore Link
                        RRMedia
                        RRExtended
                        DFXVoice
                          embedapplist=iGuidance is in my rr.ini. with this setting, switching skins manually works fine. if you have a "DAYSKIN" and a "NIGHTSKIN" button, these commands cause iguidance to close.
                            the code for these commands does not tell RR to mind the embedapplist before reloading the skin. I just checked the source. small oversight i'm sure. I should be able to fix this tomorrow (gotta reinstall mappoint first argh!)
                              Did you fix this?
