CURRENTTRACKTIME skips seconds?
  • CURRENTTRACKTIME skips seconds?
    ok just noticed that, i don't know if it is the current version + the one before, or it goes way back..
    the "CURRENTTRACKTIME" label actually skips seconds !!!
    sometimes it skips 1-2-3-4-5 seconds.. i mean it is "00:45 then it goes "00:50: lol
    it happens randomly mostly it skips 1 second or so..
    any ideas why, isn't RR supposed to update that once a second??
    OK, no worrys, i got it, it seems that i was having a variable updated 4 times in one second in some screens, that made RR have trouble keep up updating the rest of the labels.. ok now
    but it keeps missing a second every 10 seconds or so.. in all skins.. i wonder if there is a solution for that
      its all relative to your cpu usage.. higher the load the more numbers get skipped
      Live mp3Car Facebook Chat
        yeah i guess thats it.. but even in BMV without any flash in it it still skips 1 sec every 10... and i am using a sempron 2800+
        i also believe it might be down to the number of labels defined in a .skin
          yes that plays a role too.. basically labels are updated every 100th (or 1000th) of a second... but the more labels u have defined the more labels it has to update in that amount of time.
            as flash objects in various skins continue to play even if we change the .skin this produces more stress to the cpu.. and too bad we can't use /discardable as it does not work on skins that have flash.. any news on that.. that might help that issue a bit
              I've noticed that when the clock misses seconds, the videos are playing asyncronized.
              If I restart RR, or restart the whole PC, both of them seem to work fine.
              This usually happens after waking up from hibernation.
                during high-load periods of CPU this stuff tends to happen.. RR only updates the screen once per second exactly to save CPU load, so it's expected that with any delays by hardware/other applications, that it might skin a second every now and then.
                Ride Runner RR's Myspace
                  welcome back mate and thanks..
