some bugs...
  • some bugs...
    1)
    'Calc GPS speed on current unit
    SPD = GPS.speed * IIf(ISUnits, 1.1852, 1.150779)
    should be
    SPD = GPS.speed * IIf(ISUnits, 1.852, 1.150779)
    2)
    wrong types (only examples):
    UseVars.Add "False", "speedatt" -> UseVars.Add False, "speedatt"
    UseVars.Add "True", "speedattmute" -> UseVars.Add True, "speedattmute"
    UseVars.Add "70", "speedattvolzero" -> UseVars.Add 70, "speedattvolzero"
    if you enter everything as string you will run into troubles...
    Example:
    this will evaluate to the wrong result:
    (UseVars("speedattvolb") + UseVars("speedattspeedb")) ^ UseVars("speedattspeeda")
    this returns the correct value:
    (CLng(UseVars("speedattvolb")) + CLng(UseVars("speedattspeedb"))) ^ CLng(UseVars("speedattspeeda"))
    happy debugging...
    monschein.org
    1-I am not sure of the proper conversion value.. you're probably right... I'm hoping that's only for the GPS Attenuation ?
    2-This was done on purpose... at least on VB6 SP6 the conversion is automatically done for you without needing the CLNGs I thought. Or at least, I didn't run into trouble because of it.
    Ride Runner RR's Myspace
      1) i think its the only occurence...
      2) yes, there is a conversion, cause you couldnt calculate something with strings, but the implicit conversion is sometimes wrong. This results in "random" like errors is not easy to find - just try my example...
      monschein.org
