This topic is closed.
  • wintv
    ok forget all i asked - found it - thanks anyway - ill let u know how i get on : got the updates here :
    Hi Guys - i got myself a wintv hvr900 usb tv tuner.
    I installed it and it works great using its own application. I ran register.bat in the wintv folder and then tried the rrwintv exe.
    The result i get is as follows :
    failed to load '' from . Your version may be outdated. Make sure you are using the version of the control that was provided with your application.
    any help please ?
    I don't know, and have never tried how well (if at all) RR would work with digital tuners from any manufacturer -- assuming the interface is different, it would probably need some shim/wrapper as it would probably not work directly (unless extra code is added).
    Ride Runner RR's Myspace
