Gonna have to bear w/ me on this one...
  • Gonna have to bear w/ me on this one...
    To start, here's an ONSKINSTART that's in my MMIv2.0 skin:
    skin's ExecTBL.ini
    Code:
    "ONSKINSTART","STARTUPFILEBR||STARTUPIGCONFIG||WRITEUTILICON||SAVEDRIVECONFIG3||SETTHEME||WRITEWEB||LOADLATESTFLDATA||LOADLATESTMLDATA"
    I'm not not gonna bore you w/ the code for each command as they are quite lengthy. The summary of each command is a series of SAVETOSKIN, WRITETOFILE, ADDTOFILE commands to various *.skin and *.txt files that is used in my skin using the INC command line with tons of variables defined in skin.ini
    So here is the oddity that I am experiencing.
    Let's say you initally start RR with MMIv2.0 as the starting skin. It'll follow the ONSKINSTART command as it should writing to each file w/ details to complete various skin files when loaded.
    If you use skin browser to switch skins, say BMV2, even though ONSKINSTART is defined only in the MMI skin's ExecTBL.ini, it'll run MMIv2.0's ONSKINSTART command and write the files in the BMV2 skin folder.
    I don't now if that was intended or not, but should this be happening? I mean, shouldn't those ExecTBL commands stay only w/in the skin? I'd hate to think that I'm cluttering up another skin folder w/ my startup files.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    definitely shouldnt and doesnt happen with my skin . As long as that exectbl.ini is in a skin folder its ignored by rr unless that skin is loaded. Are you sure that you dont have it in the rr exectbl.ini and dotn realize it .
    Live mp3Car Facebook Chat
      LOL! I'm absolutely sure it's not the $rrpath$ ExecTBL.ini.
      And my skin's ONSKINSTART defined in my skin's ExecTBL.ini is definitely writing my startup files to other folders once I move away from MMIv2.0 to other skins using skin browser.
        Originally posted by Enforcer View Post
        maybe you need to show us the code for at least one of the commands that doing it.
        Okay.
        skin.ini
        Code:
        UTIL01icon1=IMG,178,130,45,43,"$UTIL01icon$",OFF
        UTIL01icon2=IMG,178,130,45,43,"$UTIL01icon$",ON
        UTIL01icon3=IMG,178,130,45,43,"$UTIL01icon$",DOWN
        UTIL01icon4=IMG,178,130,45,43,"$UTIL01icon$",EMPTY
        UTIL01icon5=IMG,178,130,45,43,"$UTIL01icon$",OUT
        UTIL02icon1=IMG,178,177,45,43,"$UTIL02icon$",OFF
        UTIL02icon2=IMG,178,177,45,43,"$UTIL02icon$",ON
        UTIL02icon3=IMG,178,177,45,43,"$UTIL02icon$",DOWN
        UTIL02icon4=IMG,178,177,45,43,"$UTIL02icon$",EMPTY
        UTIL02icon5=IMG,178,177,45,43,"$UTIL02icon$",OUT
        UTIL03icon1=IMG,178,224,45,43,"$UTIL03icon$",OFF
        UTIL03icon2=IMG,178,224,45,43,"$UTIL03icon$",ON
        UTIL03icon3=IMG,178,224,45,43,"$UTIL03icon$",DOWN
        UTIL03icon4=IMG,178,224,45,43,"$UTIL03icon$",EMPTY
        UTIL03icon5=IMG,178,224,45,43,"$UTIL03icon$",OUT
        UTIL04icon1=IMG,178,271,45,43,"$UTIL04icon$",OFF
        UTIL04icon2=IMG,178,271,45,43,"$UTIL04icon$",ON
        UTIL04icon3=IMG,178,271,45,43,"$UTIL04icon$",DOWN
        UTIL04icon4=IMG,178,271,45,43,"$UTIL04icon$",EMPTY
        UTIL04icon5=IMG,178,271,45,43,"$UTIL04icon$",OUT
        UTIL05icon1=IMG,178,318,45,43,"$UTIL05icon$",OFF
        UTIL05icon2=IMG,178,318,45,43,"$UTIL05icon$",ON
        UTIL05icon3=IMG,178,318,45,43,"$UTIL05icon$",DOWN
        UTIL05icon4=IMG,178,318,45,43,"$UTIL05icon$",EMPTY
        UTIL05icon5=IMG,178,318,45,43,"$UTIL05icon$",OUT
        UTIL06icon1=IMG,178,365,45,43,"$UTIL06icon$",OFF
        UTIL06icon2=IMG,178,365,45,43,"$UTIL06icon$",ON
        UTIL06icon3=IMG,178,365,45,43,"$UTIL06icon$",DOWN
        UTIL06icon4=IMG,178,365,45,43,"$UTIL06icon$",EMPTY
        UTIL06icon5=IMG,178,365,45,43,"$UTIL06icon$",OUT
        UTIL07icon1=IMG,178,130,45,43,"$UTIL07icon$",OFF
        UTIL07icon2=IMG,178,130,45,43,"$UTIL07icon$",ON
        UTIL07icon3=IMG,178,130,45,43,"$UTIL07icon$",DOWN
        UTIL07icon4=IMG,178,130,45,43,"$UTIL07icon$",EMPTY
        UTIL07icon5=IMG,178,130,45,43,"$UTIL07icon$",OUT
        UTIL08icon1=IMG,178,177,45,43,"$UTIL08icon$",OFF
        UTIL08icon2=IMG,178,177,45,43,"$UTIL08icon$",ON
        UTIL08icon3=IMG,178,177,45,43,"$UTIL08icon$",DOWN
        UTIL08icon4=IMG,178,177,45,43,"$UTIL08icon$",EMPTY
        UTIL08icon5=IMG,178,177,45,43,"$UTIL08icon$",OUT
        UTIL09icon1=IMG,178,224,45,43,"$UTIL09icon$",OFF
        UTIL09icon2=IMG,178,224,45,43,"$UTIL09icon$",ON
        UTIL09icon3=IMG,178,224,45,43,"$UTIL09icon$",DOWN
        UTIL09icon4=IMG,178,224,45,43,"$UTIL09icon$",EMPTY
        UTIL09icon5=IMG,178,224,45,43,"$UTIL09icon$",OUT
        UTIL10icon1=IMG,178,271,45,43,"$UTIL10icon$",OFF
        UTIL10icon2=IMG,178,271,45,43,"$UTIL10icon$",ON
        UTIL10icon3=IMG,178,271,45,43,"$UTIL10icon$",DOWN
        UTIL10icon4=IMG,178,271,45,43,"$UTIL10icon$",EMPTY
        UTIL10icon5=IMG,178,271,45,43,"$UTIL10icon$",OUT
        UTIL11icon1=IMG,178,318,45,43,"$UTIL11icon$",OFF
        UTIL11icon2=IMG,178,318,45,43,"$UTIL11icon$",ON
        UTIL11icon3=IMG,178,318,45,43,"$UTIL11icon$",DOWN
        UTIL11icon4=IMG,178,318,45,43,"$UTIL11icon$",EMPTY
        UTIL11icon5=IMG,178,318,45,43,"$UTIL11icon$",OUT
        UTIL12icon1=IMG,178,365,45,43,"$UTIL12icon$",OFF
        UTIL12icon2=IMG,178,365,45,43,"$UTIL12icon$",ON
        UTIL12icon3=IMG,178,365,45,43,"$UTIL12icon$",DOWN
        UTIL12icon4=IMG,178,365,45,43,"$UTIL12icon$",EMPTY
        UTIL12icon5=IMG,178,365,45,43,"$UTIL12icon$",OUT
        skin ExecTBL.ini
        Code:
        "WRITEUTILICON","WRITE01||WRITE02||WRITE03||WRITE04||WRITE05||WRITE06||WRITE07||WRITE08||WRITE09||WRITE10||WRITE11||WRITE12"
        "WRITE01","WRITETOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL01icon1$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL01icon2$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL01icon3$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL01icon5$"
        "WRITE02","ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL02icon1$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL02icon2$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL02icon3$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL02icon5$"
        "WRITE03","ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL03icon1$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL03icon2$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL03icon3$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL03icon5$"
        "WRITE04","ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL04icon1$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL04icon2$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL04icon3$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL04icon5$"
        "WRITE05","ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL05icon1$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL05icon2$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL05icon3$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL05icon5$"
        "WRITE06","ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL06icon1$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL06icon2$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL06icon3$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL06icon5$"
        "WRITE07","WRITETOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL07icon1$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL07icon2$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL07icon3$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL07icon5$"
        "WRITE08","ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL08icon1$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL08icon2$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL08icon3$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL08icon5$"
        "WRITE09","ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL09icon1$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL09icon2$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL09icon3$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL09icon5$"
        "WRITE10","ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL10icon1$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL10icon2$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL10icon3$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL10icon5$"
        "WRITE11","ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL11icon1$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL11icon2$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL11icon3$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL11icon5$"
        "WRITE12","ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL12icon1$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL12icon2$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL12icon3$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL12icon5$"
