Screen resolution awry when set to "default"
  • Screen resolution awry when set to "default"
    When using the current RR Config program I find that if I don't manually set the screen resolution/refresh EVERY time I open the Config program, it sets RR to a "default" of 1920x1200x32 (or something like that) and my Xenarc can't handle it (unintelligible lines across the screen). This is especially problematic since I have RR in the startup folder so it'll start with Windows. It requires a Safe Mode boot to fix the problem.
    Anybody else get this?
    Try setting resolution in general.ini file in your skin.
    OriginalWidth=800
    OriginalHeight=600
    ShowWidth=800
    ShowHeight=600
    ie.
    Original to the original resolution of the skin / Show to the resolution you want it to be.
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
      do you actually need RR to set the resolution for you ? cause you could look for the
      "resolution=" in RR.INI and remove it.. but it could be an issue with the config.. I haven't tested it, but it should not save the resolution= line to the INI if it's set as "default".
      Ride Runner RR's Myspace
        I guess I'll speak up, that WAS an issue with the config that was issued with the last RR release, but if you go and get the latest config, it won't happen.
        @wizz
        FYI, those settings only apply to the skin part, his problem is the actuall reslolution that the screen is using.
        Next in line: RRMedia v2.0
        DFX 5.1.1 Skin
        Appstore Link
        My RideRunner Plugins
        RRMedia
        RRExtended
        DFXVoice
          Thanks Blue ZX3! I thought I had the latest version, apparently not.
