Video - bug of "transition" screen
  • Video - bug of "transition" screen
    If I use the effects of transition with the Video (I use MPC ,and setting the "Iinternal Video") when I returns the first one turned by the full screen everything black screen.
    I feels the video, but is not seen.
    If disable the effects, then all ok.
    Mauri
    Yeah i found this out month's ago mauri.
    You can either turn off global transitions and add effect=# (where # is your chosen transition number) to each individual .skin or i believe there is another method of fixing it with skin entry/exit transition timing which has been added to recent rr releases.
    Originally posted by Nomader View Post
    ok folks..no need to disable the global transition in rr.ini.
    just disable the "EFFECTOUT", in the video skin..This is what is causing the problem, not the "EFFECTIN"
    just put this in the video skin
    /EFFECTOUT=-1
    You don't need to change EFFECTIN just EFFECTOUT.
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
      You can either turn off global transitions and add effect=# (where # is your chosen transition number) to each individual .skin or i believe there is another method of fixing it with skin entry/exit transition timing which has been added to recent rrconfig releases.
      You can find "EFFECTIN" and "EFFECTOUT" in BlueZX3's new RRCONFIG.
      Thanks Griff1.
      Add in my Video.skin this:
      /EFFECTOUT=-1
      and work well now!
        Great,i'm glad i could help.
          I'd like to know where exactly you found them("EFFECTIN" and "EFFECTOUT"), cause I am pretty sure that they only exits at the RR skin code level.
          Next in line: RRMedia v2.0
          DFX 5.1.1 Skin
          Appstore Link
          My RideRunner Plugins
          RRMedia
          RRExtended
          DFXVoice
            I didn't find them,if you look at my first post in this thread i'm actually quoting Nomader.
            I thought it was a setting you'd added but i didn't know for sure.
            I wasn't aware of the commands,i was just going off what was said here = http://www.mp3car.com/vbulletin/road...sec-video.html
            EDIT: I think i got a bit confused...i re read the post i was quoting and see these are changes you added to RR at the code level and not to the RRConfig,my mistake.
            I'll edit my above post so as not to confuse anyone else,thankfully Mauri understood what it all meant better than i did...DOH
