Possible bug in the EXEC command:
  • Possible bug in the EXEC command:
    RR v9/10/07
    An extra set of quotes is showing up after using the EXEC command.
    ExecTBL.ini:
    Code:
    "CHANGESETUPRRDRIVEPATH","LOAD;SETUPRR_CHANGEPATH.skin"
    Command1:
    Code:
    L14,155,89,492,38,0,0,0,18,"Arial","EXEC;CHANGESETUPRRDRIVEPATH",
    debug.txt
    Code:
    10/10/2007 1:51:51 PM: Que Exec: True, setuprr_skin1.skin, "SETUPRRDRIVEPATH", False
    10/10/2007 1:51:51 PM: Executing: LOAD;SETUPRR_DRIVEPATH.skin
    10/10/2007 1:51:52 PM: Leave Exec: False, setuprr_skin1.skin, LOAD;SETUPRR_DRIVEPATH.skin, False
    10/10/2007 1:51:52 PM: Enter Exec: False, setuprr_drivepath.skin, "CHANGESETUPRRDRIVEPATH"", False
    10/10/2007 1:51:52 PM: Que Exec: True, setuprr_drivepath.skin, "CHANGESETUPRRDRIVEPATH"", False
    10/10/2007 1:51:52 PM: Executing: CHANGESETUPRRDRIVEPATH"
    10/10/2007 1:51:52 PM: Leave Exec: False, setuprr_drivepath.skin, CHANGESETUPRRDRIVEPATH", False
    10/10/2007 1:51:55 PM: Enter Exec: False, setuprr_drivepath.skin, "QUIT", False
    10/10/2007 1:51:55 PM: Que Exec: True, setuprr_drivepath.skin, "QUIT", False
    10/10/2007 1:51:55 PM: Executing: SendMsg;RRCDRip;showplugin
    10/10/2007 1:51:55 PM: Que Exec: True, setuprr_drivepath.skin, "bye", False
    10/10/2007 1:51:55 PM: Executing: QUIT
    10/10/2007 1:51:56 PM: Shutdown
    Command2
    Code:
    L14,155,89,492,38,0,0,0,18,"Arial","EXEC;LOAD;SETUPRR_CHANGEPATH.skin",
    debug.txt
    Code:
    10/10/2007 1:53:52 PM: Que Exec: True, setuprr_skin1.skin, "SETUPRRDRIVEPATH", False
    10/10/2007 1:53:52 PM: Executing: LOAD;SETUPRR_DRIVEPATH.skin
    10/10/2007 1:53:53 PM: Leave Exec: False, setuprr_skin1.skin, LOAD;SETUPRR_DRIVEPATH.skin, False
    10/10/2007 1:53:54 PM: Enter Exec: False, setuprr_drivepath.skin, "LOAD;SETUPRR_CHANGEPATH.skin"", False
    10/10/2007 1:53:54 PM: Que Exec: True, setuprr_drivepath.skin, "LOAD;SETUPRR_CHANGEPATH.skin"", False
    10/10/2007 1:53:54 PM: Executing: LOAD;SETUPRR_CHANGEPATH.skin"
    10/10/2007 1:53:54 PM: Invalid Skin file: setuprr_changepath.skin"
    10/10/2007 1:53:54 PM: Leave Exec: False, setuprr_drivepath.skin, LOAD;SETUPRR_CHANGEPATH.skin", False
    10/10/2007 1:53:58 PM: Enter Exec: False, setuprr_drivepath.skin, "QUIT", False
    10/10/2007 1:53:58 PM: Que Exec: True, setuprr_drivepath.skin, "QUIT", False
    10/10/2007 1:53:58 PM: Executing: SendMsg;RRCDRip;showplugin
    10/10/2007 1:53:58 PM: Que Exec: True, setuprr_drivepath.skin, "bye", False
    10/10/2007 1:53:58 PM: Executing: QUIT
    10/10/2007 1:53:59 PM: Shutdown
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    I'll check it out.. probably a wrong size calculating the command size. I believe EXEC is normally used followed by || in labels, that's probably why it most of the time works.
    Ride Runner RR's Myspace
