Bug in Web module in RR (wbrowser.skin)
  • Bug in Web module in RR (wbrowser.skin)
    So following instructions on the new embedded web plugin, I've added a list region to show the favorites. The only problem is if you still use Firefox, anytime the song changes, RR will hide FF and show the song list instead. It goes like this.
    1. FF is displayed in skin just fine
    2. Song changes
    3. FF disappears. Skin now shows the song list (where you define the favorite list)
    4. You have to tap on the screen to get FF back.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
    Sounds to me like you're preparing a skin for the web plugin (invoked by the PLUGIN command) when you're actually using the built-in support (using the WEB command).. the built-in support is the only one that works with FireFox, but it does not support the custom list of favorites as the Web Plugin does.. if you define a list in wbrowser.skin using the built-in support, then it will become a standard playlist -- which will display songs and show itself when a song changes.
    Ride Runner RR's Myspace
      So if I use Firefox, I should comment out the list definition, right?
        if you use firefox with the built-in support you should not have a list in wbrowser.skin (yes). If you use the actual web plugin (IE based) then you should have a list in wbrowser.skin to manage the favorites.
          thanks, guino.
