RR 11/02/07 built in video bug?
  • RR 11/02/07 built in video bug?
    latest RR 11/02/07, has a problem with the built in video player..
    it won't load anything..
    problem is not there with 10/26/07 release.
    hav not found any other problems yet
    I'm experiencing the same video problem in the latest version (11-02-07).
    Sure hope the kids don't find out about it before it gets fixed
    The road is long but we are getting there.
      I'll have to test it.
      Ride Runner RR's Myspace
        Found the issue, will post an update shortly
          man weren't you supposed to be travelling till the 22nd lol
            Bug fixed with newest patch release.
            Boy that was close!!
            Have an nice trip Guino and thanks
              Where do i get this newest patch ?? I tried the updater and it doesn't work.
              Just tried downloading the latest RR and re-installing as well and still the same problem.
              Got it from here : http://guino.home.insightbb.com/rrbinary.htm
              Am i doing something incorrect ?
              I also noticed that i cant change skins now .... maybe thats another bug ??
                you should just replace Roadrunner.exe
                  I've done it.
                  No effect. Still buggered.
                  Downloaded the files 5 mins ago.........
                  Leonardo Da Vinci
                    I re-installed everything , but i still get the same - the Roadrunner.exe was also re-installed but it ddint seem to help ... is there a link for the newest patch ?
                      make sure you have deleted
                      your last download of the rr binary or re download to a different folder .
                      i have just downloaded in the last 2 min's and all is working now
                      Riderunner / Genesis
                      Wifiman_NET:Version 1.0.0
                        Just re downloaded the file.
                        Replaced rr.exe.
                        Still buggered
                        Video will play in preview pane using MPC but nothing in main video screen. DVD or mpeg files.
                        Keep getting MCi errors in debug file.
                        MCI Open Error: 277
                        MCI Size Error: 261
                        MCI Play Error: 263
                        Oh, one other thing. I'm running a full xp install, not a chopped down version.
                        Leonardo Da Vinci
                          OK , i think i found my issue anyway so ill let you guys know , though its possibly different.
                          I re-installed TinyXP again , but this time i included the IE and MSN files and drivers - after OS install i installed RR and it worked on Video straight away.
                          Not sure if that will help anyone else , but it worked for me.
                            This is a codec/dilter/filetype issue.. load a .MPG file and it'll probably play for instance -- if it doesn't there's something major wrong in your OS. Do check your RoadRunner.exe is dated of 11/4/07.
                            Replaced rr.exe.
                            Still buggered
                            MCI Open Error: 277
                            MCI Size Error: 261
                            MCI Play Error: 263
                              I am traveling.. in Atlanta for the time being.
