iList on menu.skin cause RR to crash with Run Time Error 438
  • iList on menu.skin cause RR to crash with Run Time Error 438
    If you put an ilist on the menu.skin, when RR loads it will crash with this error.
    Run Time Error 438 - Object Doesn't Support this Property or Method
    if you load RR without the ilist, it will load fine.
    Even if you copy over the menu.skin with one that has an ilist and "reloadskin" RR will still work fine. But if you exit RR and restart, it will crash again.
    It seems like the ilist is trying to initialize before RR has fully loaded the code that supports it.
    beer replenishment fund
    mp3car live search
    I'll try it.. the load of the first screen is a little more picky then the load of secondary screens in RR.
    Ride Runner RR's Myspace
      not sure if this was fixed or not in the 12/6 update, people in my skin thread have reported success with it, but i am still getting errors if i have an ilist on the main menu and and also have an SD line. With the SD line i get error 13 type mismatch.
      mp3car live search
        it was supposed to be fixed on 12/6 -- that's where you get the error 13 ? you may want to post your menu.skin so I can try it.
          its somewhat fixed in the fact you can run it with an ilist on the main menu, but if you also have an SD line on this same screen you get the error 13 type mismatch. i have removed the SD lines from the main menu as they really wernt needed, the code was just copied and pasted from another screen i had with ilist working. So for the most part its fine and there really isnt any reason to have an SD line on the main menu at least until formatting support for ilist is enabled.
          also, i was thinking cuz there are a lot of people who are still unable to run a skin that has ilist enabled for various reasons. There needs to be some kind of additional error checking or a better way to handle the initdx automation error. If RR detects that there are any problems with running DX it should automatically disable the ilist support and fall back to standard lists, gracefully instead of hanging. Also if there was an option in rr.ini to turn ilist support on/off
          useDX=True/False
          would make life easier for those who have a skin with ilist enabled but are unable to run them and dont know how to properly edit them or which .skins to edit to disable it.
          mp3car live search
            Can you post the SD line you used ? and where it was (before/after the ilist) I swear I tested that as well.
            All good ideas btw.
              i was just thinkin the same thing about an option to disable ilists. would be useful for those who test on a VM or access their carpc via one.
