Playlist Browsing Bug
  • Playlist Browsing Bug
    When browsing a playlist, the items displayed does not display ID3 formated data. At least not all of it.
    Here's what I mean. This is an example of a playlist I just saved. The playlist has a total count of 35 songs.
    The number of items that display the ID3 tag data seems to coincide w/ how many items I display in the playlist. In my case, my playlist displays 12 items at a time and the retained ID3 tag data is always the first 12 items.
    When I change the playlist window to show only 4 at a time, then save the playlist, only the first 4 items retain their ID3 Tag data.
    EDIT: In addition, using the command "ADDTOLIST" does display ID3 tag data when browsing a new or existing playlist.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    When you save a playlist, only the items to where RR gathered ID3 information will be saved with the id3 data.. so you'd have to make a list, scroll through it and then save it, and the items which RR displayed ID3 for, should have it in the playlist file when you save.
    Ride Runner RR's Myspace
      Oh.
      I didn't know that.
      Sorry to bug.
        Its the same way as winamp handles the playlist editor, only fills in data that is showing.
        Next in line: RRMedia v2.0
        DFX 5.1.1 Skin
        Appstore Link
        My RideRunner Plugins
        RRMedia
        RRExtended
        DFXVoice
          there is a way to make all the data show by opening winamp and checking metadeta on startup but prepare for a LONG startup every time winamp starts.
          Live mp3Car Facebook Chat
            The name of the saved playlist isn't visualized into the field PLAYLISTNAME with RR 12/06/07.
            It is visualized only RR 11/04/07
            winamp installed v2.95
              re "The name of the saved playlist isn't visualized into the field PLAYLISTNAME with RR 12/06/07.
              It is visualized only RR 11/04/07"
              Hows does this eactly work then? I am not getting any playlist showing up. Here is my skin file. Any suggestins ?
              RoadRunner Skin
              RRScreen "audioplayer"
              audio_player_off.jpg,audio_player_off.jpg,audio_pl ayer_on.jpg,audio_player_down.jpg
              /, I, x, y, w, h, Code;INDICATORCODES
              I,622,70,39,43,"SMS_ARRIVED_PHOCO:b"
              I,579,66,43,49,"MISSED_CALL_PHOCO:b"
              /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
              L,504,67,57,22,255,255,255,17,"Arial Narrow:B","CPU",""
              /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
              B01,6,166,66,84,"VISU","Visualization"
              B02,72,166,65,84,"SHUFFLE/REPEAT","Shuffle/Repeat"
              B03,139,165,65,85,"SEARCHLIST",""
              B04,206,165,64,84,"MENU;sort_menu.skin",""
              B05,6,253,66,84,"MASTERMUTE","Mute"
              B06,72,253,65,84,"VOL-","Volume-"
              B07,136,253,66,84,"VOL+","Volume+"
              B08,206,251,66,86,"MIXER","Mixer"
              B09,7,417,65,84,"PREV","Prev/FW"
              B10,72,417,65,84,"PLAY","Play"
              B11,140,417,64,84,"NEXT","Next/FF"
              B12,205,415,65,85,"MINUS1",""
              B13,8,510,64,79,"STOP","Stop"
              B14,75,510,63,80,"SCANMODE",""
              B15,140,510,65,80,"load;playlistmanager.skin;Play list manager||SETPATH;$PLAYLISTPATH$",""
              B16,205,510,64,81,"LIST||!Browse","Playlist"
              B17,729,166,64,75,"PGUP","Page up"
              B18,729,241,64,75,"UP","Up"
              B19,729,357,64,78,"DOWN","Down"
              B20,730,434,64,78,"PGDOWN","Page down"
              B21,731,515,64,78,"EXIT","Exit"
              I01,440,536,135,24,"BOTTOMPL"
              I02,444,159,135,30,"TOPPL"
              I03,75,510,65,80,"SCANMODE:b"
              I04,695,75,46,44,"SHUFFLE"
              L,399,65,90,21,255,255,255,17,"Arial Narrow:B","=CPU Load",""
              I05,741,75,46,44,"REPEAT"
              I06,36,278,23,31,"MASTERMUTE:b"
              T,7,187,263,382,"","","","","","","","","","",""," ","","","","","",""
              /, T, X, Y, WIDTH, HEIGHT, CMD0, CMD1, CMD2, CMD3, CMD4, CMD5, CMD6, CMD7, CMD8, CMD9, CMD10, CMD11, CMD12, CMD13, CMD14, CMD15, CMD16, CMD17
              /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
              S01,15,373,245,35,015,373,245,35,H,01,"POINTER2.gi f",12,"MASTER","Master"
              S01,276,557,453,34,276,562,453,24,H,01,"POINTER2.g if",12,"SONGPOS",""
              L08,150,125,355,24,255,255,0,22,"Arial Narrow:B","PLAYLIST","Playlist"
              L03,150,18,637,45,255,255,0,22,"Tahoma:B","TRACKNU MBER||= / ||TAGTITLE||= /","SCROLL-LEFT"
              L07,145,352,60,20,255,255,255,13,"Arial Narrow:B","VOLUME","Volume"
              L08,400,94,90,20,255,255,255,17,"Arial Narrow:B","STATUS","Status"
              L02,610,125,80,20,255,255,255,17,"Arial Narrow:B","CURRENTTRACKTIME","Current track time"
              L01,705,125,80,20,255,255,255,17,"Arial Narrow:B","TRACKTIME","Total Track Time"
              L09,149,63,132,28,255,255,0,18,"Arial Narrow:B","TIME","Time"
              L10,150,93,130,30,255,255,0,18,"Arial Narrow:B","DATE","Date"
              /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, played color R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name
              S01,290,187,433,350,255,255,255,000,000,000,255,24 5,000,000,000,000,255,255,255,TRUE,16,"ARIAL NARROW:B"
              /, A, x, y, w, h, color R;RGB, G, B
              A01,290,187,430,344,000
              /, J, x, y, w, h
              J01,25,19,122,130
              X,Mp3Art
              END
              VIA EPIA M10000 LVDS 1Ghz Motherboard,
              256Ram,80Gig,
              Lilliput 7" In Dash Touchscreen
              Panasonic Slimline Slot-in Cdrw/dvd Player,
              USB Gps Reciever,
              Belkin Bluetooth dongle
              Belkin USB wifi
              Carnetix CNX-P1290 60W Power Regulator
                Sorry.... found it.
                Needed to put winamp.dll in my rr root folder.
                256Ram,80Gig,
                USB Gps Reciever,
                Belkin USB wifi
