setvar
  • setvar
    in skin commands.txt:
    "SETVAR" - This allows you to set a global variable in RR. Those variables can be used for simple reference in the skin commands
    or be used to toggle between different groups of commands on skins (using BYVAR command).
    Example: "SETVAR;APPPATH;C:\MyApp\Myapp.exe"
    Then you can reference the variable APPPATH like this: "RUN;$APPPATH$"
    Note: SOME (but not all) settings in RR.INI can be changed in runtime.
    Note2: You can use ++ in this command when you'd like to delay reference to || on a command or label:
    [HL]Example1: Label Code: "$MYLABEL$" -- "SETVAR;MYLABEL;DATE++= ++TIME" (Displays DATE and TIME)[/HL]
    Example2: Command Code: "$MYCMD$" -- "SETVAR;MYCMD;AUDIO++PAUSE" (Executes AUDIO and PAUSE)
    The highlighted bit does not work. tried it manyy times in many scenarios. just doesnt work.
    there's nothing wrong with it -- you just made me spend time testing it again. It works fine, you probably just don't have a label large enough to fit the information for display.
    Ride Runner RR's Myspace
      sry to upset, i still cant get it to work, and i know my labels large enough. its probably something im doing. ill keep looking at it, sorry to bother
        maybe you're running an older/buggy version ? post your .skin file and I'll look at it.
          Got the same problem that SETVAR is not execute in label code
          Code:
          L03,202,369,370,24,#COL3R#,#COL3G#,#COL3B#,16,#FONT1#,"SETVAR;MYVAR;ABC||=$MYVAR$","CENTER"
          The label display nothing with above code
