mpg4 video
  • mpg4 video
    hiya i am using roadrunner with the digital fx skin i have managed to get roadruner to play the .3gp files in the video section but cant seem to get mpg4's to play.
    how do i go about sorting this out
    thank you
    Not a skin or RR issue, you need the correct codec installed on your computer. Will the file play outside of RR?
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
      yes it does by any chance you know where i can download such codecs
      cheers
        Have you defined the file type in rr config?
        For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and there you will long to return.
        Leonardo Da Vinci
          What he said, if plays outside of RR it should play in RR. With media player classic I use ffdshow codec.
          MediaLaunch for RR
          Online Check for RR
          Locker for RR
            yes it plays outside of rr and it is defined in the rr.ini as well
              WHAT app are you using to play the file OUTSIDE RR ? If you're using Mplayer, VLC or some other player with a built-in decoder, you still need the codec installed to play it in RR.
              I suggest you install FFDSHOW following the FAQ thread.
              Ride Runner RR's Myspace
