RR Freezing in Video Player
  • RR Freezing in Video Player
    RR keeps freezing when ever I try to go in to the video player. Is there something that I need to do to get this to work?
    PROBLEM SOLVED IN POST 8
    New Age Garmin - Skin for RR
    Happens with both my Skin and the BMV2 skin
      Is there any video being loaded?
      Perhaps change ur video directory so that nothing plays by default.
      Does the media player work on its own?
      Ive got some files that crash media player when invoked within RR, but work in fine media player along. *shrug*
        double post
          Few times it happened to me it was the video file itself corrupt. I moved the file then restarted RR. It was fixed (i did have to browse for another video file tho').
          OLD SYSTEM (DEAD)
          Intel D945GCLF2 Dual Core ATOM
          Lilliput 7" 629GL 2008 LED Backlight
          BU-353 USB GPS Receiver / iGuidance / IGO8
          M2-ATX Power Supply
          RideRunner Front End / Various Skins
          Windows XP SP3
            Seems to be the fiels, but cant understand why. They play fine outside of RR. Also tried other files that worked once before and they start to play then RR just quits (closes completely).
              Here is the error message that comes up when playing video files
                PROBLEM SOLVED,
                seems I had some setting mixed up. I had it set to in RR to use the built in player and to not autohide the video.
                Should be the opposite. Uncheck "Built In Player" and check "Video Auto Hide"
