can't launch map monkey embedded
  • can't launch map monkey embedded
    I've read through the FAQ, and many of the other posts, But I still can't get Map monkey to launch embedded.
    If I set map monkey as an external GPS, it will run fine.
    It all used to work fine on my previous install.
    Software:
    Map Monkey ver. 1.1.348
    Road Runner Ver. 14.0.0.162 (installer)
    Clean install XP SP2
    Here's what I have tried so far.
    Set GPS app. as map monkey
    set path to map monkey executable
    Changed settings in settings.ini (map Monkey)
    Any help would be greatly appreciated.
    S2.
    P.S. I have made shure that the install folder is Road Runner (with a space)
    which skin ? see if you have destinator_gps.skin in the skin's folder -- otherwise it won't work. I'd recommend trying it with BMV2 first to check.
    Ride Runner RR's Myspace
      Exact same problem here. Using the CFX Green skin, and it does indeed have a desitinator_gps.skin
      Path inside the skin file is pointing to the correct MapMonkey exe. Should I post the destinator_gps.skin file?
      I've tried other skins as well. Same issue.
      GPS section of rr.ini:
      Code:
      [GPS]
      gpsmode=0
      mapmonkeypath=C:\DestinatorApps\Map Monkey\MapMonkey.exe
      gpspath=C:\DestinatorApps\Map Monkey\MapMonkey.exe
      gpsname=Navigation
      overspeed=75
      gpsport=0
      mappointmap=1
      mapcountry=United States
      mapcity=
      mapautozoom=true
      isunits=true
      usegpsserv=false
      gasfinderautorefresh=false
      Aw heck, I'm bored, so I'm posting the skin file to save some time in case it is requested:
      Code:
      MEDIACAR Skin
      MEDIACAR MainMenu Skin
      /Common buttons
      /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
      B01,0,12,135,78,"MAIN","Main Menu"
      B01,0,92,135,84,"AUDIO","Audio"
      B01,0,178,135,82,"VIDEO","Audio"
      B01,0,261,135,82,"GPS","GPS"
      B01,0,345,135,82,"LAUNCH","Apps"
      B01,0,429,135,85,"PHOCO","Phone"
      B00,0,519,77,82,"VOL-","Vol-"
      B00,78,519,68,82,"VOL+","Vol+"
      B00,146,519,72,82,"MUTE","Mute"
      /Date, Time, Volume
      /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
      L01,709,20,78,38,255,255,255,18,"GE Drover","TIME","CENTER"
      L02,703,54,85,19,19,46,76,12,"Arial:B","DATE","CENTER"
      L00,17,524,60,20,255,255,255,11,"Arial:B","=VOLUME","Left"
      L00,85,524,50,20,255,255,255,11,"Arial:B","VOLUME","Left"
      /, I, x, y, w, h, Code;INDICATORCODES
      I01,158,546,41,36,"MUTE:b"
      I02,665,16,23,29,"HEADING"
      I03,556,64,51,11,"ONLINE"
      /, IMG,XXX,XXX,XXX,XXX,"IMAGE.GIF|JPG|BMP",[LAYER]
      IMG,556,64,51,11,"online_indicator.gif",ON
      IMG,556,64,51,11,"online_indicator.gif",DOWN
      IMG,158,546,41,36,"mute_indicator.gif",ON
      IMG,158,546,41,36,"mute_indicator.gif",DOWN
      /Song LCD
      L10,150,15,503,31,255,255,255,20,"GE Drover","TRACKNUMBER||=. ||TRACKNAME","SCROLL-LEFT"
      L02,154,58,73,19,19,46,76,11,"Arial:B","STATUS","LEFT"
      L02,230,58,65,19,255,255,0,11,"Arial:B","CURRENTTRACKTIME","LEFT"
      L02,303,58,65,19,19,46,76,11,"Arial:B","TRACKTIME","LEFT"
      L02,374,58,33,19,19,46,76,11,"Arial:B","=ETA:","LEFT"
      L02,408,58,63,19,19,46,76,11,"Arial:B","MM;ETA","LEFT"
      L02,470,59,31,19,19,46,76,11,"Arial:B","=ETR:","LEFT"
      L02,506,59,48,19,19,46,76,11,"Arial:B","MM;ETR","LEFT"
      L10,610,48,55,31,255,255,0,18,"Arial:B","GPSSPD","RIGHT"
      L02,661,60,40,19,255,255,0,10,"Arial:B","=mph","LEFT"
      /Media Buttons
      B00,224,519,79,82,"RRPREV","Previous"
      B00,303,519,61,82,"PLAY",""
      B00,364,519,74,82,"RRNEXT",""
      B00,447,519,68,82,"MM;ZoomIn",""
      B00,517,519,66,82,"MM;ZoomOut",""
      B00,584,519,67,82,"MM;Destinate_Address",""
      B00,652,519,67,82,"MMDETACH||MM;CloseMapMonkey||LOAD;destinator_gps_full.skin;Map Monkey||RUN;C:\DestinatorApps\Map Monkey\MapMonkey.exe;Map Monkey",""
      B00,720,519,72,82,"MM;CloseMapMonkey||EXIT",""
      /, A, x, y, w, h, color;RGB
      A01,141,91,649,420,42,98,147
      END
      2000 Jeep Cherokee Limited 4WD
      Lilliput 7"
      VIA EPIA M10000, 512M, 80G WD
      Soundblaster Live! 24-bit
      Phoenix Gold SLD44 Line Driver
      Griffin Radioshark (reboxed)
        Hi guino.
        I was using the BMV2 skin that came with the installer, Destinator skin present in folder.
        I've just tried substituting an edited version of the BMV2 skin from an earlier install (known good), and that dosen't work either. Current version of the skin works fine on old install.
        S2.
          didn't know anybody still used MapMonkey. The author 'Ninja Monkey' vanished a few years ago after threats of law suits etc.
          I thought most people had moved on to D6 / D7 as it uses a newer routing engine and looks nicer
          If you want to play cutting edge games have a look at Igo/Navngo and Sygic Drive
          My Nissan 200SX @ Silverstone
          NOW SADLY WRITTEN OFF!
          My Car's spec list + pics
          Stealth CarPC fab'ing...
            fixed
            fixed my problem.
            Set config to External and set window name to "Map Monkey"
            All is well again
            Lilliput 7"
              In the end I gave up. I have set up the CF/D6 bodge - works well! I'm just going to edit the BMV2 skin now so that i have some control over winamp.
              Shame there's no uk maps for iGuidance - looks good.
              S2
                I have got Map Monkey to run embedded again. I went back to the .exe from 11-02-07, and all is good.
                Map monkey may be old and outdated, but it's good and stable with good speed cam support. and with a little fiddling D6 maps will work!
                Would be good if someone could make a fully D6 version of map monkey though.
                S2.
