rr and winamp vis problem
  • rr and winamp vis problem
    hi!
    i want to embedded a visu of winamp in RR
    i read a lot of posts, but nothing.
    i use winspy, the vis title is visualizer, in the RR config i try to put the class of visu and the title but nothing.
    in my skin i have an application tag also.
    what i can do and what is it wrong?
    thanks
    First, and formost... you're going to have to give some more details..
    Like which visual, what window title(s) you have tried or used, which ver of winamp(does matter), then once you post them we can try to suggest what you need to either try or do.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
      hi!
      thanks
      winamp 5.13
      the visu name is classic spectrum analyzer http://www.winamp.com/plugins/details/165966
      i try with classic spectrum analyzer, with classicspectrum but nothing
      the window of visu is visualizer
      thanks
        Use "!Winamp Gen!AVS" (without the quotes)
        DFX 5.1.1 Skin
        Appstore Link
        RRMedia
        RRExtended
        DFXVoice
          i put visuname=!Winamp Gen!AVS in rr.ini but nothing
          are there others modification i have to do?
            you have to open up winamp standalone and setup the visu, too.
            what skin?
            DFX 5.1.1 Skin
            Appstore Link
            RRMedia
            RRExtended
            DFXVoice
              i have a personal skin
              what i have to set in winamp?
              i set the visu that i want and stop. ok?
              other?
                The easiest way instead of retyping it is look in this DFX help file, uner the "How Do I..." section and it tell you how to set it up. It is for a different skin but the setup is same, just ignore the skin references...
                DFX 5.1.1 Skin
                Appstore Link
                RRMedia
                RRExtended
                DFXVoice
                  ok i will try.
                  but i think that is for him visu
                    ok.
                    if i put a button like this "LOAD;audio_player.skin;;;Spectrum Analyser"
                    it woks but in audio skin not in menu skin
                    i want put visu in menu skin
                    help : )
                      just in case anyone else is trying to do this.... the correct line in rr.ini should read visuname=!Winamp Gen!Classic Spectrum Analyzer
                      '03 Acura TL Type S
                      Radio Relocation [90%]
                      OEM Navi Removal [0%]
                      Hardware Acquisition [99%]
                      Software Acquisition [100%]
                      Testing [80%]
                      Installation - ASAP!!
                        When I active the VISU winamp remains open on exit from RR.
                        Someone you have a solution or this is a bug?
