Resume from hibernate, no sound.
  • Resume from hibernate, no sound.
    The problem I have is that when RR comes out of hibernation I have no sound. I know this problem has been covered before but no one found an answer so I thought Id try resurrecting it.
    I have checked and nothing is muted, just deadly silence.
    At the moment Ive set windows to shutdown instead of hibernate and as you would expect everything works fine on restart but I really want to use hibernate because my system resumes so fast.
    Thanks in advance for any help.
    What motherboard/OS?
    Chrysler 300 - Fabricating
    http://hallert.net/
      BTW, check this:
      http://www.mp3car.com/vbulletin/887887-post51.html
      http://hallert.net/
        Originally posted by Chairboy View Post
        I'll give it a go but WinAmp is running after resume.
        I'm using a Dell GX with an Intel 2.3Ghz dual core and XP Pro SP3.
        My guess is it's an audio driver problem although they are bang upto date.
          Possibly, but disabling that plugin is an easy troubleshooting step.
          http://hallert.net/
            if you have a creative2nx thats probably the cause.
              i've got a creative audigy 2 and i've also had this problem,it wasn't the sound card though.
              I found that if i set winamp to show i could see winamp's volume was all the way down,after a whil i found i had a setting in RR for fading in the music on resume and disabling it sorted it for me so maybe it's a bug in that code or just a timing issue.
              P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
                If you still have this problem, I found that sometimes the pre-amp in winamp goes to 0, effectively muting music. Is it all sound (like GPS as well) or just winamp releted (music mostly, i guess)?
                  Thanks but the first thing I did when this happened was check the mixer settings and nothing was muted or turned down.
                    RGR. I didn't know if you checked the preamp in winamp which doesn't show up in Windows mixer. Not that it would really even help, i haven't found a solution to that anyways...
                    The only other thing I can think of is see if you have some strange ACPI script that is running when resuming from hibernate. Although even that would likely show up in the mixer...
                    Sorry I couldn't help you...
