Variables/labels/sliders stop updating after reusme from hibernation
  • Variables/labels/sliders stop updating after reusme from hibernation
    Every time I resume from hibernation all labels and sliders stop refreshing. Flash animations like the clock on DigitalFX4 keep working correctly. The labels and slider will refresh if I press a button like volume+ but it will only refresh for that instant where the button was pressed.
    Applications like the gauges screen in DFx4 and RRCam stop getting values from the GPS variables.
    Exiting and restarting RR brings everything back to normal. This system was working perfectly but after updating to the latest version of RR (as of this writing) the issue began happening.
    To replicate the problem I just need to start RR and then hibernate. After resuming from hibernation all values stop refreshing. Exiting RR and opening it again will work until next hibernation. Tried changing the "hibernation aware" setting in RR but made no difference besides messing with the current song resuming
    Specs:
    WinXP Pro SP3
    RR December 2008 release
    DigitalFX4
    USB GPS
    USB camera
    USB wireless adapter
    USB 3G modem
    lilliput touchscreen
    hibernateaware=true
    MUST BE SET!!!!
    and how about posting a debug.txt from a session
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      Originally posted by mitchjs View Post
      hibernateaware=true
      MUST BE SET!!!!
      Tried setting the "hibernate aware" setting from the RRConfig tool but made no difference. Well actually it affected that the songs would no longer keep playing when resuming from hibernation when hibernateaware is set. With hibernateaware = FALSE, songs starts playing as soon as windows comes out of hibernation, no need to touch anything to wake up RR.
      I will upload the debug.txt tomorrow
        The problem normally is related to either a setting that was changed during the update, or some external application setting. I would like you to do two things to try define the issue:
        1-Post a zip with your debug log hibernating/resuming and a copy of your rr.ini
        2-Run the BMV2 skin to see if when you resume the labels are frozen or not, if it doesn't freeze, then it's a skin/script/plugin issue
        Ride Runner RR's Myspace
          Made a quick test today on my way to work. Tried the BMV2 skin and it didn't show the freezing issue when resuming from hibernation. I think that should be enough to go back to troubleshoot the DFx4 skin instead of RR.
          I'll update if I find the cause of the problem on the skin.
            Did you fix this? I have the same problem ever since I updated to riderunner.
            Skins:
            /showthread.php?t=83814 (R.I.P.)
            /104373-golf-skin.html (R.I.P.)
            /106214-metal-spin-release.html(RIP)
            using own vw gypsy clone
            On 2nd PC: 1st one died.
              Only thing I haven't tried yet is formatting and the issue is still there. So far everything points to be DFx skin causing the problem.
                I don't use that skin, what plugins do you use?
                I have
                X,milage
                X,rrpetrol
                X,SkinTool
                X,RRMediaDb
                latest flash
                Skins:
                  I have
                  X,milage
                  X,rrpetrol
                  X,SkinTool
                  X,RRMediaDb
                  latest flash
                  I tried the carwings and bm2 skins and they don't show the freezing bug so I continued assuming it was the DFx skin. What skin do you use?
                  As far as plug ins, I have whatever get installed by default but only actually use
                  RRCam (camera)
                  NetRadio
                  Weather, interactive weather map
                  Music with BlueZx's MediaDB
                  visualizations
                  GPS with iGuidance
                  Tomorrow when I get in the car I'll check what other plugins get loaded
                    It's my own skin that hasn't been released. I have used a mish-mash of ideas from lots of other different skins.
                    Skins:
                      Can you make a small sample skin that replicates the issue?
                      Im thinking 1 screen with a couple labels and sliders should be enough to help troubleshoot the problem.
                        I have this screen up most of the time and it happens all the time. The only way to fix is to manually close and reopen rr. Even the RELOADRR cmd doesnt correct the problem.
                        Code:
                        RoadRunner Skin
                        RRScreen nowplaying
                        B,198,91,329,45,"RELOADRR",
                        B,0,87,194,56,"EXIT",
                        B,604,87,194,56,"LOAD;audio_player2.skin",
                        L,148,398,89,40,255,255,255,20,"VAGRounded Lt:B","TRACKTIME","RIGHT"
                        L,38,398,89,40,255,255,255,20,"VAGRounded Lt:B","CURRENTTRACKTIME","LEFT"
                        L,295,269,490,50,255,255,255,30,"VAGRounded Lt:B","TAGALBUM","SCROLL-LEFT"
                        L,88,18,699,51,255,255,255,30,"VAGRounded Lt:B","TAGTRACKNUMBER||= - ||TAGARTIST||= - ||TAGTITLE","SCROLL-CENTER"
                        L,295,193,490,50,255,255,255,30,"VAGRounded Lt:B","TAGARTIST","LEFT"
                        L,295,340,490,95,255,255,255,30,"VAGRounded Lt:B","TAGTITLE","WRAP"
                        S01,17,449,64,137,17,441,64,150,v,01,"vslider1\pointer.gif",19,"MASTER",
                        Y,"vslider1\slider_*.gif"
                        S01,15,380,249,13,15,380,249,13,h,0,"vslider2\pointer.gif",6,"SONGPOS",
                        J,37,159,225,212
                        A,0,144,288,297,
                        B,2,2,82,82,"LOAD;exit_menu.skin",
                        B,205,441,113,149,"PREV",
                        I,671,440,115,150,"REPEAT"
                        I,554,441,115,150,"SHUFFLE"
                        B,439,441,113,149,"NEXT",
                        B,322,440,113,149,"PLAY",
                        B,85,441,115,149,"VISU",
                        L,537,101,58,36,255,255,255,20,"VAGRounded Lt:B","PLAYLISTCOUNT","CENTER"
                        L,17,504,64,31,255,255,255,18,"VAGRounded Lt:B","VOLUME","CENTER"
                        L,101,405,73,23,255,255,255,12,"VAGRounded Lt:B","STATUS","CENTER"
                        END
                        Skins:
                          Code:
                          RoadRunner Skin
                          RRScreen nowplaying
                          J,37,159,225,212
                          A,0,144,288,297,
                          END
                          If you can, pack your skin file and related files and images and attach it here. I'll copy it to the carpc and test it.
                            Ok attached my skin
                            Skins:
