App.Path not work
  • App.Path not work
    i have truble in vb6 code
    i have my converted plugin into F:\Programmi\RideRunner\Plugins\silabs folder
    if i call "msgbox App.Path" riderunner give me "f:\document and setting\spidermunz\desktop"
    i can't load my plugin because App.Path return to me a wrong folder
    Are you sure your using vb6?
    In vb6 App.Path=path here exe was executed from. vb.net is different and sounds more like what your describing.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
      yes i using vb6 not vb.net
        ha i knew i wasnt the only person with this issue! I uninstalled/reinstalled vb suite to get app.path to work correctly.
        Live mp3Car Facebook Chat
          Very odd...Mine has always worked correctly
          DFX 5.1.1 Skin
          Appstore Link
          RRMedia
          RRExtended
          DFXVoice
            ok i try
              It does seem flakey with RRPlugins though. ie whilst when it first starts it will actually contain the path the app (plugin is in) it will later on pick up either RR' path, the skin path or some other path, that is why I stick it in a variable when it first starts now.
                Well....as I've said, I've never had a problem with the app.path thing..
                And with the upcomming plugin std change, plugins won't be storing any data in their folder (like they are not supposed to accod to win stds).....TBC
                DFX 5.1.1 Skin
                Appstore Link
                RRMedia
                RRExtended
                DFXVoice
                  never had a app.path issue myself, but as mentioned above, it does reflect the location where the application is running from, NOT where the EXE is saved.
                  Ride Runner RR's Myspace
                    i have solved the app.path problem
                    but now i have this new problem:
                    i have thios in my code
                    Public Declare Sub SetMute Lib "usbsilabs.dll" (ByVal mute As Boolean)
                    the plugin is running into riderunner but don't load the ussbsilabsdll
                    some other command of the same plugin works perfectly
                      And what is the assoc code that would call that sub cmd?
                      DFX 5.1.1 Skin
                      Appstore Link
                      RRMedia
                      RRExtended
                      DFXVoice
                        Public Function ProcessCommand(CMD As String, frm As Object) As Integer
                        Dim rrSDK As Object
                        Set rrSDK = CreateObject("RideRunner.SDK")
                        Dim Index As Integer
                        Select Case LCase(CMD)
                        Case "mutesilabs"
                        SetMute True
                        silabmute = True
                        ProcessCommand = 2 'Command completed
                        Case "unmutesilabs"
                        SetMute False
                        silabmute = False
                          That should work. IDK, try SetMute (False)
                          I do also see a BIG no no! Creating RR's object like that is not the way to do it, that would create a obj ref with every cmd that flows through your plugin, and is a waste of CPU that isn't doing anything if not executing any of your cmds.
                          your better off moving the "Dim rrSDK As Object" line to the top of the RRExtention class and then move the "Set rrSDK = CreateObject("RideRunner.SDK")" line inside the RRExtention Class_Initialize function.
                          This way your only creating it once when the plugin is loaded.
                          DFX 5.1.1 Skin
                          Appstore Link
                          RRMedia
                          RRExtended
                          DFXVoice
