latest release does not load radio.ini
  • latest release does not load radio.ini
    any idea why the latest release does NOT load radio.ini when entering the fm skin..
    i tried an older rr release and it works fine..
    the radio.ini is in place in the rrpath but the list (standard lists and ilist) is empty.
    edit:the hotfix update does not fix that
    Temporary solution; if you copy radio.ini contents to rcache.ini it works for me..
      same problem here, will try the rcache.ini, thx
      Sig, smig...
      Ford Flex Toshiba Excite 7.7 Install
      CoverMess - Cool Flash Covers
      FlashFlex - Flash Components for your skinning pleasure
      Mazda Millenia, Road Runner
      YouTube - Road Runner, IGO8 PC, Dashcommand OBD, Visteon HD Radio
        this is a bug related to the now file management in RR, now fixed and will be on next release.
        Ride Runner RR's Myspace
          thanks guino..by the way what is exactly the new "file manager"?
            This is an internal thing.. it's some structuring Mitch did for the files used by RR (INIs ,etc) so they can be stored/used from a location approved for the newer Windows OS versions.
