[RESOLVED] Plugin manager does not update labels when using iList
  • [RESOLVED] Plugin manager does not update labels when using iList
    I'm working on the plugin manager screen for my skin, working off of the carwings dynamic lite as a base. I noticed that if I leave the list as a standard DL then the associated plugin labels (version, description, status, etc.) get updated as I click on different items in the list. However, if I change the list to be an iList those labels no longer get updated.
    I'm using the same label codes as are used in carwings:
    L,710,175,80,30,#LCDR#,#LCDG#,#LCDB#,18,#LCDFont#, "pluginmgr|version|$DLPLUGINNAME$","LEFT"
    My guess is that somewhere in the plugin it updates $DLPLUGINNAME$ with the currently selected item name on each click of the list, but maybe not on every click of an iList?
    I haven't been able to find that variable anywhere in the exectbl or .ini files for carwings, so I apologize if there's some simple explanation/solution I'm missing...
    Thanks.
    snap i found this problem way back when mitch built it, i have managed to get 1 out of 6 comp's to accept ilist in plugin manager, but it was short lived, i did bring this to mithc's attention , and we have found no solution for it as yet, but it only seems to be a very small amount of users that have this problem, as no 1 else apart from you has pubilcly mentioned this. i have even re-built 3 pc's and still get the same result,but if you select in the list then refresh the list you will see the labels update ,||pluginmgr;list
    but your right the PI dose up-date the $DLPLUGINNAME$ ondirclick,
    sorry i know its no help to you but just wanted to add that your not alone,
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
      ok, here how it works
      the SKIN must me named: "pluginmgr.skin" and a DL type
      and when a MouseDown of a item ("ONDIRCLICK" happens)
      dlpluginname gets set
      if skin isnt named that, it wont happen
      i dont know anything about ilist... if u send me the .skin file with ur change to ilist, i can eval
      mitch
      -Thanks
      Mitch
      www.rush2112.net
      Sun, Come shine my way
      Wind, Carry me home
      The piece of me that died
      Will return To live again
        and thats how i have it direct copy from carwings, no changes made except adding ilist line
          show me the line please
          i have found a bug in RR, that if the TYPE is "LST" it is tried to get ID3 for
          since its not a song, it gets corrupted in the internal list
          i can fix... but i need to fully understand lists
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
            /, IL, LIST, SelImg, UnselImg, EndImg, LimitMode, Drag, MaxSpeed
            IL,DL,transparent.bmp,sel.bmp,end.bmp,0,50,60
              thanks!
              i have a test build, i would like you to test it... do u know where to find me?
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                well done mitch all good
                  Ondirclick works ,but I noticed that the up/down buttons don't update labels could it be the same bug
                    carputer1, those look like they never worked
                    geeze, i got some bad beta testers, and ME too!!!
                    you would think i would try the arrows... not just click on the damm list
                    i will figure out what to fix
                    and post u a new build
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      If you need another tester, I'd be more than happy to help.
                        carputer1, its posted on my FTP
                        thanks for finding this OLD bug!!!! (more like an omission, i just never added the code for it)
                        -Thanks
                        Mitch
                        www.rush2112.net
                        Wind, Carry me home
                          spamm, WE really do need testers...
                          and when i mean testers, i mean someone who can test stuff within a few hours...
                          not "ill put it in my car and test, and get back to you in a few days"
                          hopefully most people have say have a setup of ther carputer and run it on desktop maybe in a Virtual machine, or on the real machine (as i do, since i have no carpc)
                          mitch
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
                            all good working cheers mitch
                              I posted one more build
                              i cleaned up a IF statement that was really confusing, and root of this issue
                              please test new build, also test audio_browser make sure no id3 issues...
                              shouldnt be, its simpler code now
                              -Thanks
                              Mitch
                              www.rush2112.net
                              Wind, Carry me home
