2 Hits for Mute.
  • 2 Hits for Mute.
    I am noticing that it takes 2 hits for the mute to happen. I dont know if it something I did, or if it is a feature,or a bug. I uninstalled and reinstalled RR, and tried this with Carwings, DFX4 and my custom version of DFX4.
    1. Version of RideRunner being used (should really be using the lastest).7/17/2009
    2. Skin Being used (Best to have tested with more than one skin, esp the Default : Carwings)Carwings, DFX4, My custom DFX4
    3. Full description of problem including any steps taken by yourself to resolve it. Unistalled and reinstalled RR. Tried with 3 skins, The problem is not there with a virgin RR.ini file. But as soon as I run Config.exe, and put in my settings, it shows up again.
    4. Attach a zip file with the following
    5. I have used the search function of the forum to see if the problem has occured before.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
    Sounds like you have "3 State Mute Button Enabled". Run RRConfig, go to the "Speed Att Vol" tab and uncheck "Allow 3 State Mute Button to Enabled/Disable Automatic Volume". Also make sure "Adjust Volume Based on Speed from GPS" is also unchecked if you don't intend to use it.
      Thanks. I will look for that.
      EDIT: That's exactly what it was. I was unaware of that feature.
        Click here->Rep points!!!
          That's a bit cheating, no?
          Next in line: RRMedia v2.0
          DFX 5.1.1 Skin
          Appstore Link
          My RideRunner Plugins
          RRMedia
          RRExtended
          DFXVoice
            I did him a service. He's allow to give me rep. I just pointed it out for him. Actually, its just flagrant self-promotion.
            What do you expect from someone who had to blackmail an admin to get a custom title.
