"onsuspend","MAIN"
  • "onsuspend","MAIN"
    since ilists sometimes do not resume i have set in the exectbl.ini to :
    "onsuspend","MAIN"
    it works fine if hibernate is trggered by the powersupply or windows..but when hibernate is triggered by RR via "HIBERNATE" (not directly , but from an "exit.skin"), 2 seconds after resuming rr suddenly closes!!. it works ok when "HIBERNATE" is sent directly (via skintool for example)
    You may want to try a resume delay. This issue is very hard to debug because it's basically DirectX loosing the loaded surfaces for the list -- RR has detection to re-build them after hibernate/standby (but sometimes DirectX will not re-create the surfaces anyway).
    Ride Runner RR's Myspace
      I think that he understands that, but is saying that there is a different issue when calling the hib cmd from w/i RR.
      Next in line: RRMedia v2.0
      DFX 5.1.1 Skin
      Appstore Link
      My RideRunner Plugins
      RRMedia
      RRExtended
      DFXVoice
        This is weird because the same exact code used on Hibernate through the exit menu, is executed when sending it through skintool.
        However, if through skin tool it works, I would like you to change the "HIBERNATE" command in the exit menu to this:
        "RUNQ;$RRPATH$exec.exe|hibernate"
        Let me know what happens..
        Guino.
          i will just out of curiosity..but i changed to "onsuspend","reloadskin" and it does the same thing, so no issues..i am away for a few days i will try when i get home..thanks guys
