I can't see the Preview in the Launch.Skin
  • I can't see the Preview in the Launch.Skin
    Originally posted by guino View Post
    The launch feature in non-profile mode (which is what I use) seems to be working here (though it may not be hiding the image correctly when there's nothing to display). There's no "requirement" as to what the folder name should be and generally the problems reported on this feature are either skin or ini/structure related.
    OK, so I need some help troubleshooting. The LAUNCH command itself works fine. The problem I'm having is the launch screen used to show a preview image (JPG) of the highlighted program based on the ini and jpg sharing the same name as the subdirectory its in. My system doesn't show the preview image - everything else on this screen works fine.
    Originally posted by mitchjs View Post
    the J command is not obsolete
    Gizmo, launch images work for me... and should work from any path
    "C:\Program Files\Road Runner\launch" should work fine
    Mitch and I had a discussion about the J code during the September AlbumArt fiasco and he said something about the new code doesn't like touching other stuff. Unfortunately, the LAUNCH.SKIN has the J code inside the A code that embeds the external program.
    RR.INI:
    [General]
    launchpath=C:\Program Files\Road Runner\launch\
    MAIN MENU BUTTON:
    B20,701,501,098,048,"LAUNCH",@RRFUSION@
    No related coding in exectbl.ini.
    Launch.Skin code:
    Code:
    RoadRunner Skin
    RRScreen macstyle_dayMenu
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B01,001,550,095,050,"MAIN||BYVAR;CURRENTSOURCE;CHECKNETRADIO<<RDSCHANGE<<ARTISTBACK<<ARTISTBACK<<ARTISTBACK<<ARTISTBACK<<ARTISTBACK<<YTSWAP"
    B02,101,550,078,050,"SPEEDATTDN>>VOL-||SWITCHBUTTON;4||SWITCHBUTTON;2>>VOL-"
    B03,181,550,078,050,"MuteSpeedatt","Mute"
    B04,261,550,078,050,"SPEEDATTUP>>VOL+||SWITCHBUTTON;2||SWITCHBUTTON;4>>VOL+"
    B05,341,550,078,050,"RRPREV","Prev"
    B06,421,550,078,050,"STOP","Stop"
    B07,501,550,078,050,"PLAY",@STOP||Play@
    B08,581,550,078,050,"RRNEXT","Next"
    B09,661,550,138,050,"EXIT||BYVAR;CURRENTSOURCE;CHECKNETRADIO<<RDSCHANGE<<ARTISTBACK<<ARTISTBACK<<ARTISTBACK<<ARTISTBACK<<ARTISTBACK<<YTSWAP",@MAIN||BYVAR;CURRENTSOURCE;CHECKNETRADIO<<RDSCHANGE<<ARTISTBACK<<ARTISTBACK<<ARTISTBACK<<ARTISTBACK<<ARTISTBACK<<YTSWAP@
    B10,001,001,098,048,"SENDMSG;FreeDrive;night||NIGHTSKIN","Day Toggle"
    B11,001,051,098,048,"MIXER","Mixer"
    B12,701,101,098,048,"AUDIO","MP3"
    B13,701,151,098,048,"VIDEO",@DVD@
    B14,701,201,098,048,"XM","XM"
    B15,701,251,098,048,"RADIO","Radio"
    B16,701,301,098,048,"TV","TV"
    B17,701,351,098,048,"GPS","Gps"
    B18,701,401,098,048,"PHONE","Phone"
    B19,701,451,098,048,"WEB","Web-Browser"
    B21,001,101,078,048,"UP","Up"
    B21,459,101,237,31,"PgUP","PgUp"
    B22,001,151,078,048,"LAUNCH",""
    B23,001,201,078,048,"CLOSE","Close"
    B24,1,251,78,48,"DOWN","Down"
    B24,1,309,78,48,"NEXT","NEXT"
    B24,461,513,234,34,"pgdn","page Down"
    B50,105,005,790,050,"APPOSK","osk"
    /, I, x, y, w, h, Code;INDICATORCODES
    I01,620,070,100,030,"MUTE"
    I02,130,070,080,030,"REPEAT"
    I03,210,070,080,030,"SHUFFLE"
    I04,290,070,080,030,"STEREO"
    I05,380,070,080,030,"SCAN"
    I07,460,070,080,030,"LOCAL"
    I06,441,7,55,49,"Heading2"
    I07,540,70,80,30,"ONLINE"
    /, IMG, x, y, w, h, File Name, Option;IMGLAYER
    IMG,552,75,57,14,"Online_Indicator.gif",ON
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L01,650,010,150,030,000,000,000,13,"Tahoma:B","TIME",""
    L02,130,030,100,030,000,000,000,13,"Tahoma:B","VOLUME","Volume"
    L03,113,010,317,025,000,000,000,13,"Tahoma:B","BYVAR;CURRENTSOURCE;TRACKNUMBER||= - ||TRACKNAME<<Frequence||= - ||rdsname||= - ||rdstext<<TRACKNUMBER||= - ||TRACKNAME<<TRACKNUMBER||= - ||TRACKNAME<<TRACKNUMBER||= - ||TRACKNAME<<TRACKNUMBER||= - ||TRACKNAME<<TRACKNUMBER||= - ||TRACKNAME<<=YOUTUBE - ||YT_MOVIE","SCROLL-CENTER"
    L04,178,030,205,030,000,000,000,13,"Tahoma:B","CURRENTTRACKTIME","RIGHT"
    L05,378,030,010,030,000,000,000,13,"Tahoma:B","=/","/"
    L06,385,030,112,030,000,000,000,13,"Tahoma:B","TRACKTIME","LEFT"
    L07,230,030,100,030,000,000,000,13,"Tahoma:B","STATUS","Status"
    L08,650,030,150,030,000,000,000,13,"Tahoma:B","DATE",""
    L09,500,010,150,060,000,000,000,30,"Tahoma:B","GPSSPD",""
    L28,105,551,72,18,96,96,96,14,"GE Drover","=MIN:||=$speedattvola$||=%","CENTER"
    L10,130,050,040,030,000,000,000,13,"Tahoma:B","=ETA:",""
    L11,180,050,160,030,000,000,000,13,"Tahoma:B","CUSTOMFDETA",""
    L12,330,050,040,030,000,000,000,13,"Tahoma:B","=ETR:",""
    L13,380,050,190,030,000,000,000,13,"Tahoma:B","CUSTOMFDETR",""
    L14,650,050,085,030,000,000,000,13,"Tahoma:B","=Satellites:",""
    L15,740,050,050,030,000,000,000,13,"Tahoma:B","GPSSAT",""
    L,0,0,0,0,,,,,,"CUSTOMFDNEXTMAN",
    L,0,0,0,0,,,,,,"CUSTOMFDNEXTMANDIST",
    L,4,524,694,34,0,0,0,16,"Trebuchet MS","customfdmanfull>>CUSTOMFDROAD","Left"
    L28,707,182,87,18,192,192,192,14,"GE Drover","=DVD","CENTER"
    /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name
    S01,461,128,232,393,000,000,000,000,000,000,000,000,000,255,255,255,TRUE,13,"Tahoma:B"
    /, J, x, y, w, h
    J01,95,110,347,321
    /, A, x, y, w, h, color;RGB
    A01,080,100,620,450,000,000,000
    /, F, x, y, w, h, Movie name
    F,0,448,80,98,"GPS.SWF"
    END
    I've tried this skin with nothing but the blue section and it still doesn't work. So my guess is something in my RR.ini or skin.ini. The only thing in the skin.ini is YouTube settings so I've attached my RR.ini.
    Any help on solving this would be greatly appreciated.
    Here's what you need:
    OR
    That should take care of it -- the coverfile setting is a global setting that works with the launch path, music and video folders.
    Ride Runner RR's Myspace
      OR
      DOH!
      That worked.
