SetLabel
  • SetLabel
    Is it me or is the command SetLabel not working anymore? I have a command where I call a MENU but the label is not populating. Here is my command.
    "ESC||RM_Add2Disk1||MENU;AddSong.skin||SETLABEL;!D iskNumber;1"
    Now, AddSong pops up but the label is blank.
    NOT working for me either... Using the skin tool I cant get it to work even using the exact syntax from the Skin Commands.txt
    I think this bug can be considered CONFIRMED...
    New Age Garmin - Skin for RR
      OH yeah, I using the October release of RR...
        November update neither. Need to be looked at by the Gurus.
          I just tested this here (and works):
          L,625,25,117,25,28,68,227,18,"Arial:B","!test",""
          with command:
          setlabel;!test;Hello!
          can any of you post a .skin and command combination which isn't working ?
          Ride Runner RR's Myspace
            Im testing using the skintool
            command
            label code
            !test
              Ok works if I put the label in a skin and put the ! before the label code.
              If there is no ! then the label displays then goes blank.
              Still can't get the skin tool to get the label information though.
                with command:
                Why use a test label that starts w/ a "!"?? Was there something new that the "!" in front of a std lbl changes or does?
                Next in line: RRMedia v2.0
                DFX 5.1.1 Skin
                Appstore Link
                My RideRunner Plugins
                RRMedia
                RRExtended
                DFXVoice
                  yes... the ! does do something
                  it sounds obsoleted
                  and one should use a label and a var
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Sun, Come shine my way
                  Wind, Carry me home
                  The piece of me that died
                  Will return To live again
                    ! in front of a label is the same as "CUSTOM" in front of a label. This IS AN OBSOLETE feature and only works in the SKIN itself as setlabel will directly set the label text without ever setting/reading it again -- this means that skintool (or any other plugin) will never be able to read it.
                    As mentioned, this feature is obsolete and is only available to support older plugins/applications still using it. The RECOMMENDED way of doing exactly the same is:
                    LABEL CODE: Instead of "!TEST" use "=$TEST$"
                    COMMAND: Instead of "SETLABEL;!TEST;Hello!" use "SETVAR;TEST;Hello!"
                    The results are the same, however you CAN read the variable from skintool/plugins and furthermore, the command will work for displaying the data on ALL screens of RR without having to resend it for every screen (using SETLABEL you'd only set that label on the CURRENT screen and if you wanted to show the data on different screens, you'd have to execute SETLABEL again after every screen change - or on a timed basis).
                      The only drawback to using vars in lables that I found when starting my RRMedia PI, was that a lbls that have/use a var for the text take longer to update when you change the var compared to using the custom route. The custom route is almost instantly updated...
                      DFX 5.1.1 Skin
                      Appstore Link
                      RRMedia
                      RRExtended
                      DFXVoice
