Rescaling skin an song position slider problem
  • Rescaling skin an song position slider problem
    Found a problem with rescaling a skin together with the song position slider.
    Try this in general.ini:
    OriginalWidth =800
    OriginalHeight=600
    ShowWidth=640
    ShowHeight=480
    and click on the Song Position Slider, and you will see what i mean, the mouseclick is still using the original width, height seems to be OK...
    I think that the Volume Slider has the same problem...
    OriginalWidth =800
    OriginalHeight=600
    ShowWidth=640
    ShowHeight=480
    I'll check it out.. it's hard to test everything after adding needing features..
    EDIT: I've found the bug, and it only happens with two sliders: Song position and Video Position.. I still have to find a way to fix it..
    Ride Runner RR's Myspace
      This has been fixed in the last versions of RR...
        Thanks, working great now...
