Player XPosition and YPosition.
  • Player XPosition and YPosition.
    In the general.ini file, there is a Xposition and Yposition is set for player Top and Left position. This is work fine when RR load up the skin.
    However, I found some problem with External app, Map Monkey, Internal VIdeo (cmp) regarding the Top and Left position. Basically doesn't mater what Xposition and Yposition defined in general.ini is, those application always load at 0,0.
    When I look thru the code, most/all SetWindowPos API called is hardcode with 0, 0 instead of whatever the value in general.ini is. This problem cause those app not embeded properly if RR is not at 0,0.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    This has already changed.. in any case, the idea of setting to 0,0 was to imitially move the window which later would then be fixed up by a timer using the fixwindow function .. I probably forgot to add Posx and PosY to the application enbbeding position (because typically moving the window is enough for anything inside of it).. that's easy to fix..
    Ride Runner RR's Myspace
      I fixed the problem in my RR exe but just to let you know so you can change it.
        Fixed and tested this with 2-17-05...
