Mouse don't hide after hibernation
  • Mouse don't hide after hibernation
    New problem
    Even if I select "Mouse Hide" option, after my PC wake up from the hibernation the mouse is still visible... Any suggestions?
    Thanks to everyone, as usual
    Garo
    Author Of:
    CarPC Installation on my Seat Toledo
    ummm... I have to check this out.. never had a problem with it, but I guess I can add extra code to make sure this will not happen..
    Ride Runner RR's Myspace
      In fact, this is probably a problem of my PC since I had this problem even when I used MediaCar... However, it would be good if you could add a code to correct this
      Thanks a lot!!!
      Garo
      Author Of:
        Yeah I have this problem also, the mouse appears again after I come back from hibernation. I would greatly appreciate it if you could add some code to fix it
        My Projects:
        Old project
        2000 A4
        http://www.mp3car.com/vbulletin/show...ight=2000+audi
        New Project
        2006 Montero
        http://www.mp3car.com/vbulletin/show...6-4x4-swb.html
          Please try this versison:
          http://rmc.pimpedwheels.com/RoadRunnerBinary.zip
            Perfect!!
            This one works perfectly!!!
            Thanks a lot!!!
            Another little question: using map monkey embedded in RR, I have to "auto hide" windows start bar, otherwise it will pop up occasionally.There's a way to fix this?
            Thanks again
            Garo
            Author Of:
              Originally posted by garo
              Perfect!!
              Thanks a lot!!!
              Thanks again
              You should NOT use the auto hide option in the taskbar.. you should instead, disable the "keep taskbar on top" option.
                Thanks a lot, you're right!!! I'm so dumb that I just didn't see that option
                Garo
                Author Of:
                  Guino, can't you implement an option to hide the taskbar completely when RR is active, i can't help you with VB-code (and you probably know this already) but the Delphi code to do this is:
                  TaskBarHandle := FindWindow('Shell_TrayWnd',Nil);
                  ShowWindow(TaskBarHandle, SW_HIDE);
                  Then SW_SHOW to show taskbar again...
                  Just my humble opinion...
                    Yeah, thought about that... but some people WANT the taskbar there.. so it'd have to be an option.. and when ON, if the program crashes or you have to kill it for whatever reason, you'd not get the taskbar back!
                      Hi Guino,
                      I'm sad but occasionally the mouse reappears again... An then, after the next hibernation, it may be hidden again, without any apparent reason!
                      Garo
                      Author Of:
                        Ok... I'll make it so that between every screen it can hide/show the mouse.. how does that sound ? That's all I can think of, I mean, I know windows is showing the mouse after hibernation, but If hiding the mouse after it comes out of hibernation is not being enough, the only thing I can do is hide the mouse everytime you go from screen to screen, so in the case where the mouse would not hide, you should only see it once, and after pressing any screen button you shouldn't see it anymore.
                          I think it would be great!
                          However, is there a method to understand if the system has just woke up from the hibernation? You may, for example, check the system clock every 10 sec; if the time is different from the expected, you may hide the mouse!
                          It's just an idea
                          Garo
                          Author Of:
                            it's not that really.. when I go into hibernation, I can execute something immediatly after it comes back.. and that's where I had the mouse hiding.. in fact, I was doing it about 2 seconds after the system came back out of hibernation... but it seems there are slower crap running in the machine that is showing the mouse even after that..
                              Ok, I understand... So I think that the "changing screen" solution would be great
                              Tnx!!!
                              Garo
                              Author Of:
