Visualization Window Pop-up
  • Visualization Window Pop-up
    I'm currently using RR on my desktop. I get a problem when RR is minimized and a new song starts. After a random number seconds the visualization window (AVS window) in winamp pops up. I close the window and minimize the player again, after the start of the next song the same thing happens again. The window does not popup if you have RR maximized.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Never tried that.. so I'll take a look..
    Ride Runner RR's Myspace
      I figure out this "bug", (re) download after I've posted this message and you'll have a fix for this..
        Carpcnoobie post #47 in RR27Late thread, mentions vis popup on exiting video. I've found out that this was my problem in my earlier post when I said I got a black screen on exiting video, it is a vis popup and has not been fixed in "rr27Latefixes" which I D/L'd about 9:30GMT. Also time & date on main RR screen are drawn twice in slightly different positions making it look like it's corrupt.
        Wizz
        Car : Ford Focus Zetec S 1800cc
        Carpc :Galaxy GT-P1000 Original 7in Tab
        Mounted in "On Dash" Custom Install
          Wizz
          The font thing souds like a skin issue, please double check there isn't two lines for "DATE" and "TIME" there.. I'd try redownloading 2-27 anyway just to be sure.. I actually fixed it after I posted the release (note that it isn't even a listed change).
            I checked that straight away & there are not two lines in the skin menu.ini. Some of the other Guys in a different thread seemed to touch on it too. They were saying their LCD fonts were changed and both fonts were displayed together. This was also on the RR main screen, so I think they are describing the same problem.(this was post#57 in 2/27 release (fixes) )
            BTW I am using the main skin without the song title scroll, but including the flash anim.
            Wizz
              Do you have internationalization disabled ?
                No I haven't, never touched that option.
                This problem has only appeared on the very last update to 2/27, never before.
                Wizz
                  well, if you don't use foreign chars you SHOULD disable internationalization..
                    Just re-downloaded it now and I haven't been able to reproduce the screen pop-up. Great work.
                    Installed
                      Guino Check out new thread in Bug Tracker "Wath is this". That is exactly what I am experiencing
                      And I WILL disable internationalization.
                      Wizz
