having to press buttons twice using touchscreen
  • having to press buttons twice using touchscreen
    has anyone else been having trouble with this? when i use the touchscreen with roadrunner, (v 2.20.05) when i try to press a button for the first time, the button highlights but does not press. then i press again and the button presses. If i use a mouse it works fine. My theory is this: seems like roadrunner does not press the button unless moused over first to activate the "On" image before activating the "Down" image for the button. since using a touchscreen, you "jump" from one button to the next, the first press only activates the "On" image, so you must then press again to activate the "Down" image and then the button presses. What do you think guino?
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
    Finally someone that gave me a good description of the problem... I guess those with big fingers get this more often... when clicking any button in RR, if you let go of the mouse/screen OUTSIDE the area of the button, it will NOT execute button. This was intentional, as to allow for the user to cancel the command after pressing it... I can add an option to disable this check so that pressing a button will execute it regardless of where in the screen you let go of it...
    Ride Runner RR's Myspace
      i don't think that this is what's happening in my case because it happens even with the big buttons on the main menu. plus i don't have fat fingers. i'm going to try it with another computer just to check. i am installing my girlfriends carputer and doing some bondo work on another friends screen so i have plenty of parts to play with. i'll let you know what happens.
        Here's the thing: if the button gets Highlighted, but doesn't execute, it MUST be because after pressing it, you've dragged the mouse through it.. I'll try to add that option to execute button regardless of where it comes out at.. then I'll post a try out version so you guys can test..
          sorry guino...i just tried it again on my laptop with a brand new xenarc. same thing happens. and i'm sure i didn't drag the pointer outside of the button area. i tried it on the main menu where the buttons are huge. i can even do it with a stylus. i'm 100% sure i'm not going outside of the button area. hope you believe me.
          when in windows or any other programs, touching on the first go executes a click. it's only in rr that this happens. tried it with a couple of different skins. same behaviour. can anyone else verify this? guino, do you have a touch screen? i'm going to try downloading different touch screen drivers, but i'm doubtful that it will do anything since this problem is only with roadrunner and does not happen in windows or in other apps.
            guino, sorry i didnt explain it well enuf earlier when i mentioned this to you but this is what im experiencing as well... thanks
            '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
              I'm going to look into this deeply.. this may have happened when I allowed buttons to be within the Touchwheel.. sorry for the inconvenience..
                no incovenience and definitely no need to apologize. roadrunner is really looking good. all of your hard work is appreciated.
                  Well i had road runner running pefectly, and then today I experienced this bug. Very weird. I am sure I am not clicking and then moving out of area. like other people here I press the button, it becomes highlighted and nothing happens, i press it again a second time and then it works. can't be a coincidence that it ALWAYS works on the second try. this happened to me mostly in the audio player page. its strange beccause it worked fine all week, now all of a sudden I get this. I tried restartring my computer several times, until finally it stopped doing it. now I shut down to hibernate. so i'm hjoping when I turn it back on it will behave itself. I'd be willing to give your theory a try guino, and see if you could give an option to "cancel" that feature you mentioned
                  My Projects:
                  Old project
                  2000 A4
                  http://www.mp3car.com/vbulletin/show...ight=2000+audi
                  New Project
                  2006 Montero
                  http://www.mp3car.com/vbulletin/show...6-4x4-swb.html
                    btw I have road runner version 2-23-05 10:39 pm
                    p.s. I STILL get the problem of mouse not hiding after hibernation with this file. I was under the impression this version had something to fix it?
                    My Projects:
                    Old project
                    2000 A4
                    New Project
                    2006 Montero
                      I don't have such problem, but another user with the same problem has reported that it worked... are you sure you have the hidemouse option checked in RRConfig ? otherwise it might be out of my control... I mean, windows is probably restoring the mouse (even after I tell it to hide after hibernation).
                        I've been having the button issue as well I think, unless its the EPIA struggling to process it!!
                          Ok. guys, for all of you suffering from this issue, I believe to have found the problem... I simply forgot one little line of code: "Lastdrawn = C" <- believe me that makes a hell of a difference.. The reason why I couldn't find this problem was because I always used the mouse for "heavy" testing and that line is unecessary for it to work correctly when using the mouse..
                          Expect a fix with tonight's release...
                          EDIT: It's released.
                            that seemed to do the trick. thanx!!!
                            My Projects:
                            Old project
                            2000 A4
                            New Project
                            2006 Montero
