iGuidance embed problem
  • iGuidance embed problem
    I got it to embed ok but if i touch anywhere in the app the windows task bar goes on top of RR.
    Any ideas why that would happen?
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    You have two options:
    1-Run RRConfig and set "Hide:... Taskbar"
    2-Right Click on the taskbar, go into properties. Then make sure that "Keep Taskbar on top" and "Auto-Hide taskbar" are BOTH OFF.
    Ride Runner RR's Myspace
      il try opt#1 tomarrow.
      1990 Jeep Cherokee
        I had this problem. I didn't use the 'hide taskbar' because it seems a touch slow to 'hide' the taskbar. I simply moved my taskbar to the side and made it as small as possible. I had this same problem with MediaCar and moved the taskbar to the top and didn't have the problem anymore.
        Progress Meter:
        [|||||!||||'] 95% complete
        It's in... it's finally installed!!!! But never finished!
        "It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
