Trouble going back from TV to Main Menu
  • Trouble going back from TV to Main Menu
    In previous versions of RR (previous to 03-06 and 03-07) when I was watching TV and went back to the main menu, the TV stopped and started the music, but with mentioned versions, the music doesn't start and still sound the TV.
    żIs this a bug or is it just a functional change?
    ummm... sounds like a bug... let me try and tell you.. :|
    Ride Runner RR's Myspace
      Sorry about that.. there was a tiny bug (weird that it worked before), but just redownload and it will work.
        Ok, I have downloaded again the 03-08 version and it is fixed!!
        However, I have seen another bug related to the Temperature format. Days ago I told you than I was seeing the Temperature in a wong format.
        For example, if it is 20.45 I was seeing 2045,0C (remember we use the comma as decimal separator). You fixed it and I've been seeing 20,4 for a few versions, but now it's at the wong format again.
        I have tried selecting and unselectig the "Disable Internationalization", but it works the same in both modes.
        Thanks for your work, Guino.
          I'll look at this, I made this detection be global thing, so I probably did something wrong..
            Redownload version 3-8-05, the display format of temperature is fixed (now).
              Latecomer
              O.K. I admit I'm coming in late to the party here, but how do I get TV to work in Road Runner? I have a WinTV/FM USB and everything works fine using the WinTV software but I can't figure out how to get an embedded TV in RR.
              Also, my radio worked once and now I cant get it to respond to RR commands. Again, It works perfectly under WinTV Radio. Radiator won't store my setup so I have to open config everytime I run it and set it to external antenna,b but once I do that it works flawlessly. I assume making the adjustment at that time kills the link RR uses to talkto radiatior. I reinstalled everything to no avail.
              Step by step instructions would be appreciated.
                You just need the TV plugin (check news page on my site -- scroll down!) then you set it up to use "thin frame" and then save "channel files" in an empty folder location and hit scan. Set the same path of yopur presets in RRConfig and you're done. Of course, you will need to get a skin tiwh TV support (get the brushmetal update on my site if needed).
                For Radio, it's all about getting Radiator to work and making sure you have the "radiator" option set in RRConfig along with it's path. Radiator does not need to store your presets, BUT it does need to keep your SETTINGS -- not sure why you're haing this problem, may be you want to remove anything extra from it... I've never seen radiator not store settings..
                  Thanks, Radio now working, will try TV today.
                    Guino, how do I turn this bug back on? This is just the functionality I'm trying to achieve for thr radio, video, DVD and TV.
                      I can't wait to try the winamp tv plugin with the Avermedia PCMCIA TVcard I've just ordered. Check out http://www.avermedia.com/cgi-bin/pro...lus.asp?show=2
                      It may well be the ideal tvcard for Epia MII-owners with no room for a PCI card, like myself.
                      CarPC status: HW all done, SW needs tweaked.
                      Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
                      Software: RR, MM/FD
                        Ok. Guino, it is fixed.
                        The temperature format is now perfect.
                        Thanks a lot.
                          If you use External DVD, you can do that by not using the 'close' button on the DVD screen, you should stop audio playback first though. For TV, I still have to do some work on it because right now even if you go into the Mixer it will stop the TV and play music, then restore the TV when going back to it. This is a little more complex than people think simply because of the "go anywhere from anywhere navigational structure".
                            I'm considering buying the same card (2nd generation TV card WITH FM RADIO!!!) for my MII12000 mobo. Would welcome your review or others' reviews on this product including how good the FM radio is.
                              I'm hoping that this card will work as FM with Radiator either with the Avermedia drivers or the WDM FM driver.. I do not see it listed under radiator's compatibility list (not explicitly).. I'm sure the TV part works though..
