main screen title blanked out ??
  • main screen title blanked out ??
    I have the following visual bug in version 15/3/
    After setting the startup command in the setup program to read
    gps||main
    Roadrunner loads the gps screen and then goes back to the main screen.
    The title and the date on the top of the main screen are blanked out. Also anything that uses labels such as "status" is not shown also. Now if you enter another screen (music...) and then return to the main screen then everything is OK.
    Everything is also OK if the startup command read "gps||main||main".
    It looks to me that this is some sort of refresh bug.
    P.S. I redownloaded the mini fix as mentioned in another thread but still nothing.
    The road is long but we are getting there.
    sorry, you probably got it in the first 30 mins of the release.. I fixed it right away, so if you re-download, chances are it will work now..
    Ride Runner RR's Myspace
      I did redownload but the problem is still there. Any ideas ?
        not really.. I guess I'll double check the code... there was a little bug that I fixed, but then two other people that had it, said it's fixed.. (i saw it too) so if you say your're still having issues after redownloading just now, I don't know ... As a note -- I don't believe I updated the source code package with this fix.
