roadrunner problem
  • roadrunner problem
    guy anyone had the roadrunner freez....
    mine freez like crazy,,,,
    Also i want to what if i want to build my own skin, where can i get help
    what programing lang is used in roadrunner?
    thanks
    HOnda Accord '94
    freezes where, and how ? the only time I've heard of it freezing was when starting (flash missing) and when on the audio browser (bad pics or files -- still trying to figure it out). If you give more details I can try to find out what is your problem..
    Building skins is basically a matter of making images with whatever you want, and create definition files (.skin) with the instructions in the Skin Commands.txt file.
    Ride Runner RR's Myspace
      I have seen that if I use MM embedded to RR (skin by Ildeana) the scroll buttons skinning of MM skin don't work, all ok instead if I use the same skin with MM in stand-alone.
      I use RR update to vers. 16/03
      Strange...
      Mauri
        I've just run RR in the "dena's old style" skin with MM embbeded, found no issues.. coudn't it be something related to to your MM skin instead ??
          I have modified the Dena MM skin, with various differences and icons, it perhaps depends on this... I make then some tests I see if I resolve the problem.
          EDIT: with the new RR 16/03 the AVS of Winamp (I use Dena old style skin for RR) as soon as I launch the first time with the audio player,not animation is displayed, but the configuration utility of settings to AVS is is displayed 8 resize in the area predisposed to the vision of AVS).
          If close then reopen AVS all it becomes ok.
          This fact ONLY in the carPC
          AVS work ok in my Home PC
          Perhaps and better if I put a screenshot to understand us.
          Mauri
            I know what you mean, I have one machine that does that.. I have to see why...
              I believe the problam was simply a matter of leaving the AVS Editor ON -- but I've improved it to prevent it from embbeding all together... also trried to improve on the embbeding method to try and make sure the AVS is updated correctly.
                thanks
                Please try the latest version and let me know..
                  Hi Guino, just tried the 'TODAY' variable in flash, it shows the date for a split second, then it goes and shows the status, I have checked my code, but think its fine my end.
                  cheers
                  CdR
                  Follow me on Twitter
                  http://www.FreeICE.co.uk
                    cheers
                    CdR
                    I'll double check..
                    I've made updates to FD's source to include SDK support, also fixed a few comhooks issues on your code.. how can I send you this stuff ??
                    Let me know,
                    Guino.
